New WoodChat!
Butternut - easy to mistake for walnut, eh?
Mike Schwing from Md.
>I've been trying to figure out to what species of tree this limb belonged that was delivered to my doorstep.
Was told "almost 100 years old, very large, had green ball shaped fruits every fall that opened up to look like walnuts." The owner thought it was a walnut, but the limb I have doesn't say "walnut" to me.
Bark looks like walnut, but it is an immature limb. No dark heartwood as normally found in walnuts around here. Very thin ring of sapwood followed by a light brown heartwood that takes up 80% of the thickness.
I can post a pic here later of the limb cut in half and probably even get a razor blade slice of the pore structure, but I'm thinking at this point it is probably a butternut. In which case, it can rot where it is - too much other good wood around here to mess with butternut. That doesn't mean I haven't seen nice butternut stuff here on WC, I have, I just know its not the easiest stuff to work.
Sound like butternut thus far? I'm no expert.
Re: Butternut - easy to mistake for walnut, eh?
Re: Butternut - English walnut?
John Trant (Baltimore/DC area)
>Could be English walnut, especially if it came from Annapolis. Both walnut trees I have taken from Annapolis have been English variety which are a much lighter shade of walnut than I find elsewhere. English walnut is not as light as and is much harder than butternut.
John
Carole in VA
>Ask him if the nut was shaped more like a pecan or round and very deeply wrinkled. The butternut looks like a very hard wrinkled pecan.
Don Orr
>I'm going to agree with John T. on this one. Butternut has fairly large, 2" or more, football shaped nuts encased in a thin sticky greenish yellow husk that turns dark brown when dried. The round nuts you mentioned are more indicative of English Walnut especially if they are fairly small 1" or so. You probably know that Black Walnuts in the husk are much larger. An older common name of butternut is "white walnut".Same genus. Butternuts are excellent eating when dried.
RevDoug
>Mike,
If you decide it is Butternut and you don't want it, I do. Would even pay the postage/UPS. I love to work with it. I've turned two pieces from butternut and enjoyed it very much. Even dry it turns easily with ribbons coming off the gouge most of the time.
Opps, sounds like I'm trying to talk you into using it.
Turn 'em round,
RevDoug
Dale Stansbery
>Butternut that I've seen here in Ohio has a distinctly different bark than walnut as well. It's not nearly as deeply nor closely furrowed as walnut and the area between the furrows is smoother, if that description makes any sense.
