New WoodChat!
Crotch pieces
Crotch pieces
Crotch pieces
echo8287
>I finally got my lathe,its still on the pallet and tommorrow I am going to work on getting it set up. I had a guy that was clearing his lot tell me I could get any wood I wanted off it cause he was going to burn it up.There is some oak,shagbark hickory,sweet gum trees that were cut about 3 weeks ago. I cut some straight pieces and a couple of crotchs. I have Bill Grumbines DVD and see how to cut the straight pieces, but how do you cut the crotch pieces up for blanks? bowls or anything?
Re: Crotch pieces
Re: Crotch pieces
Gary Evans, Tallassee, TN
>There are a couple of different ways to cut crotches, depending on how big they are.
Most common is to cut through the center of the two piths. This will give you two y-shaped pieces with crotch grain on the exposed side. Since it is hard to know how far the crotch grain extends into the piece, I usually recommend using a waste block on the exposed side and let that be the bottom of your bowl or platter to maximize the figure in the finished piece.
The other way that I use, if the crotch is big enough, is to rotate the crotch 90 degrees from the first method and cut through each pith separately, taking an upside down pyramid-shaped section, which should have crotch figure on two sides. Often the offcuts will yield curly wood on the outside, below the piths.
I did this on a big maple crotch that had 4 limbs coming off. I ended up with a pyramid shape that had crotch figure on all 4 sides.
Gary
Re: Crotch pieces
Re: Crotch pieces
echo8287
>Gary thanks for the reply. I looked at the pieces I have and the bottom is about 14 inchs in diameter. The Y's are about 9 inchs. The log I cut that off of, had a huge piece with about 3 limb intersections. I couldn't lift that piece without some help though.It was maybe 30 inchs in diameter at the bottom. Thank you for that reply,David
Re: Crotch pieces
Or you could put the...
Paul in Phoenix, AZ
>...crotch on the lathe and turn something like the photo below. As long is the crotch isn't too big. These are real challenging to turn. This is mesquite about 13"D x 12"H.
Re: Crotch pieces
Re: Crotch pieces
GaryNelson
>If you have a lot of them,take and get some contractors garbage bags.They won`t bio-degrade as fast.Put some of them in there for future use.at this time of year with the sap running--they tend to split more.
A tip I found on turning--do what you want--it is you and not someone else--if you are happy--thats all that counts.The one you give the item to,will not look at the quality,but the thought.
Hickory spalts well,pecan is part of that family.there is lots of free wood--so make good use of it.Gary
