New WoodChat!
McNaughton Core Saver Questions
>Hello,
For my recen B-day I received a McNaughton coring system, one daughter gave me the standar and another gave me the mini, a set of blades and adapter.
I can not see why I need an adapter, in this picture, the adapter kit.
Re: McNaughton Core Saver Questions
Gary Ljostad
>The adaptor kit is used with the mini center saver. The dog bone shaped piece slips between two posts and makes it so you can use the mini cutters in a level position, when held up against the crossbar. The ring tightens the gap between the same two posts to keep the cutter from tiping. You definitly need this adaptor set with the mini set using the regular tool post holder.
>Gary:
I figured that, but if you look a t the pics above, it seems that this gate is already ready for the large standard and mini,
Thanks
Jorge
Gary Ljostad
>Jorge, looks like you may have a newer version. On the one I have the adaptors are needed. Looks like the one you have is diferent then mine.
Thank you!
Greg Jensen
>You do not need the adapotors. They are for people who have the old three pin head sytem. You have a four pin head.
Greg Jensen
Thanks Greg!
>We figured that already and a medium size blank was cored already, it was not hard at all.
Thanks
Jorge
