New WoodChat!
dying to know the answer
DWFII
>I'd like to dye some maple I have. I have two questions regrading this...
I have aniline dyes that I used for leather dying. they are alcohol or some sort of solvent based and **very** strong--they strongly colour the leather or wood or whatever. Are these types of dyes OK to use on wood?
And the second question is...Can dyes, especially alcolhol based dyes(but water based dyes, too) be used over tung oil? I have a vase that I'd like to dye but I tung oiled it (50%pure tung / 50% mineral spirits) because the wood was a little old. Once the tung sets up (maybe a week if I remembers Russ Fairfield's article correctly) will the dye still penetrate?
DW
In the High Desert of Central Oregon
Re: dying to know the answer
>DW
I know the leather dyes will work because I've used them. You can dilute them if necessary to knock the brightness back.
I can't answer your question on the dyes over Tung oil. Never done that.
Ron in Drums PA
>isn't tung oil "water proof" to some extent?
MAYBE, just maybe, you can try (on a sample) to mix some dye into the tung oil and see what happens. Let us know.
Fred in NC
>If all else fails, you can put a coat of a compatible tinted finish on the vase.
