New WoodChat!
not turned
not turned
not turned
Mike Schwing from Md.
>There's a good debate going on over at the WOW site about what is or is not a turning. Most of my work of late has been on the fence, but not this one. Never touched the lathe. I was commissioned to make a very fancy ladle for a woman who paid me a very high dollar amount, hope this does it justice. Curly, ambrosia maple (found at the log dump), about 15" tall, quite fun to make these. Would appreciate thoughts even though it wasn't turned. I don't think she'll use it for food use, but it is finished so anyway.
Re: not turned
Re: not turned
Tom In Red Deer
>Hi Mike
That is very fine work. Very elegant. Was that done with dry wood? How strong would it be in use?
Very, very nice...sure you are not tired of turning and turning to carving?
Tom in Red Deer
Re: not turned
Re: not turned
MP Wall
>That ladle is a thing of beauty, I don't know that I could use it, it looks way to much like art to be used. You really have the ability to look at a piece of wood and see what it is screaming to be. Awesome piece. MP Wall
Re: not turned
Re: not turned
RonZ
>Nice piece Mike, I'm sure your customer will be happy.
P.S. Thanks for being man enough to admit its origins. What if you put on its finish on the lathe bed, does that make it turned? =o)
Re: not turned
not a spoon either
Tom Sontag - St. Louis
>I think what ya got there big fella is a ladle. Now perhaps you might call a ladle a member of the spoon family, but it is clearly a much bigger dip than your typical spoon family member.
Hey, you've got to find something wrong with it or else he'll just think we are a "yes" crowd. Beautiful work.
Re: not turned
But it Turns Heads
>Mike,
Beautiful art work, Thanks for sharing it
Jorge
Re: not turned
Re: not turned
Ed Kelle
>Hi Mike
That really looks great. I guess people could argue either way over if it is a turning or not. I'd rather just admire it as a fantastic piece of woodworking.
How about giving us a little insight into how you made it?
Re: not turned
Re: not turned
>Thanks everybody, and Ed, I'd gladly tell you how I did it.
I started with a long square blank - wet wood, but only because that is what I had. I decide in my head what I want it to look like, and then trace the outline from the rear perspective on one side. I then trace the side profile on an adjoining side. After that it is taken to the bandsaw where one profile is cut out. The offcuts are taped back on and then the remaining profile is sawn. This gives you your blank, with square surfaces. From there it is simple rotary carving, with the bulk of the work being done by ball shaped Kutzall burrs. The hollowing of the ladle is done the same way, but it is into end grain so a lot more effort is required till you get it a little deep and can work the face grain.
I prefer the ball shaped bits to the sleeve types for all of the shaping involved.
I do the ladle first, saving the mass of the handle for last in case I bang it against something while working on the ladle.
When I have the shape I'm after I start smoothing and refining with finer and finer bits till I'm ready to sand by hand. I keep the blank in a plastic bag in between sessions. When done shaping, and before sanding, it goes into the microwave for a few 60 second bursts to fully dry the wood before finishing.
The main thing to keep in mind is that sanding REALLY reduces the diameter, so you have to stop shaping well in advance of the finished form. That isn't very easy to grasp in the head while you're working on the project.
Wet wood isn't really any easier to carve with these bits than dry wood, far as I can tell, but it is nicer in that the dust is heavier and falls to the ground rather than stay suspended in the air.
Truthfully, making these is way more fun, challenging and interesting than turning a bowl.
Re: not turned
Re: not turned
Ed Kelle
>Thanks for the step by step Mike!
Re: not turned
Re: not turned
charles harmon
>That was one impressive piece of work. Thanks for sharing it.
