New WoodChat!
Newbie. Starting out in Barcelona, Spain. VII
Carles
>I don't like too much bowl turning, I prefer spindle turning. But sometimes...
An incense burner in beech. 5x2 inches.
Carles.
Re: Newbie. Starting out in Barcelona, Spain. VII
Carles
>Bottom up!!!
>For someone who professes not to like bowl turning that much, you sure do a good job at it!
Carles
>Many thanks for your comments.
I haven't got a bandsaw. To prepare the wood for bowls is a heavy work for me and I prefer to be good in spindle work before.
Un saludo,
Carles.
Very elegant!
Fred in NC
>Great job, Carles!
Is an insert used when incense is burned in it?
Saludos desde EE.UU.
Re: Very elegant!
Carles
>I use an small piece of ceramics to put the incense stick in oblique position but you can make a little hole next to the rim.
Thanks.
Carles.
>If you have a tablesaw, you can "knock" the corners off with it. It's what I did before I got a bandsaw. Other than that, you can knock the corners off with a miter saw.
Carles
>no bandsaw, no table saw.
At the moment I cut the corners with hand saw. A healthy work but a heavy work too (dry beech is very hard)
Thanks.
Carles.
TomW In SouthJersey
>Very nice detail. The clean lines make it pleasing to look at.
Tom
Ron in Drums PA
>All your work is very nice Carles.
Welcome!
