Maple Burl & Bubinga Boxes
Dominic Greco in Richboro PA
>Hi Everyone,
Below are some pictures of (2) boxes I completed this past weekend. The first was turned from Maple Burl and features a Walnut Finial. I also used turquoise powder and CA Glue to fill some of the voids.
The second was turned from Bubinga and features a Dogwood finial. Since Bubinga is a nice dense hardwood, I decided to try to add some chatterwork details to the underside of the lid, as well as the base. I think I'm finally starting to get the hang of using that darn chatter tool! One big help was the relative hardness of the Bubinga.
Maple Burl Box Specs:
Outer dia.: 4 3/4"
Height: 6" (including 2 1/4" Walnut finial)
Wall thickness: 3/16"
Base dia.: 2 1/4"
Sanding Method: Sanded to 12000 Grit (MicroMesh).
Finish: PSI's Lacquer Sealer
Final: Buffed with White Diamond then given a coat of Renaissance wax
Bubinga Box Specs:
Outer dia.: 3 1/4"
Height: 5" (including 2 1/4" Dogwood finial)
Base dia.: 1 1/8"
Of the two, I favor the Bubinga box. I think I got the shape just right. I think the base of the maple burl box could have been "lighter". It comes off as sort of bulky. What are your thoughts?
Thanks for viewing.
See ya around,
Dominic
