New WoodChat!
Wolverine Setup
Wolverine Setup
Wolverine Setup
TomW In SouthJersey
>I just got a Wolverine grinding jig. I am using a Grizzly grinder that has a large wet wheel and a small white wheel. I've got the jig set up under the small wheel. The directions say the center of the wheel needs to be 6 1/4 to 6 1/2 inches above the workbench surface. I'm at 7 1/2 inches and there isn't room to raise the mount for the jig.
So I was planning to make a 1 inch high block to mount into the V on the grinding jig that holds the gouge handle to achieve the correct height.
I tried sharpening a bowl gouge and the wings are ground way too far back on the sides. Is there another solution before I make the riser block? Is anyone else using this grinder?
Tom Wright
Re: Wolverine Setup
Re: Wolverine Setup *LINK*
Joe Fleming - SD
>Tom,
Go to the SD woodturners website and click on the tips page. I have a grinding handout that explains how to set the wings up.
Joe Fleming - San Diego
San Diego Woodturners
Re: Wolverine Setup
Thank you
TomW In SouthJersey
>I found a lot of good information on the San Diego Woodturners site.
I also got a direct email from Oneway with some advice. How's that for customer service?
Thanks
