New WoodChat!
How best to dry Cherry & Walnut ?
Pete in Holland, MI
>Hey all -
Stumbled into enough cherry & walnut to make approximately 50 10-11" bowls. Am in the midst of roughing them out this afternoon and have been in the turning hobby since late last year. Don't want to lose these guys during drying. Have been doing a lot of alcohol drying recently with mixed results. Had massive failures with this process last time I used in cherry, and this if the first time turning walnut. Am not in need of any finish turning materials till this fall. Would I be safest to grocery-bag each one and let them slow dry? Don't have current access to Anchor Seal, but would it be best to order some now? Turnings are burried under the mountain of noodles until I figure out what is best.
Also - - What do you guys get for plain bowls in the 9-11 diameter range made of oak, maple, cherry & walnut? Just curious.
Back to the basement.........
Re: How best to dry Cherry & Walnut ?
Doug Trembath
>Pete, order Anchorseal from the manufacturer, U-C Coatings. Google them up and order a 5 gallon pail, probably about $40, plus shipping. Seal the entire bowl, and keep them in a low spot where there's not much air movement, and not too hot. Crawl spaces, root cellars, etc work extremely well. Unused basement corners, along the wall in the garage, I've seen many different places work. Cut some 1X2 scraps to fit into the rims of the cherry roughouts, and place them so they touch the side grain perpendicular to the end grain to keep them more round. Don't force them too hard, it just restricts the elongation some as they dry. Walnut doesn't seem to need them, in my experience.
Let 'em dry, and return them. As to the value, it depends on quality, locale, demand, market, and your salesmanship. Kind of a gray area, especially as to quality, so it's hard to give you a starting figure. Make them, then take them around and see what you can get for them.
Doug Trembath
Studio in the Woods
>I also anchorsealed a bunch of roughed bowls in cherry, maple, walnut, etc. I paint it inside and out. I've noticed no significant cracking after 1 and 2 years of drying.
I've never tried the stick support but sounds interesting. (BTW, my black walnut distorts as much or more than other woods - probably because the orientation of the blank in the tree.)
If you haven't seen it, the book, Turning Green Wood is full of useful information about blank orientation, shrinkage, drying, etc.
JKJ in East TN
