New WoodChat!
Nuts to make faceplate
Lan Brady
>I have worn out the keyboard trying to find the post about ordering nuts to make faceplate. I know the website is Mc??????.com
Pleae help my poor memory and search capabilites.
Thanks, Lan
Re: Nuts to make faceplate
Walt Hickman
>Are you looking for www.mcfeelys.com?
Good Luck
Walt
Re: Nuts to make faceplate *LINK*
Dave Peebles Lyons, Ohio!
>Hi Lan,
This may be the place you are looking for...
Best wishes,
Dave
http://www1.mscdirect.com/cgi/nnsrhm
Ed in No.VA
>http://www.mcmaster.com/
Jim Ketron
>Its www.mcmaster.com I just orderd some 1 1/4 x 8 tpi a few weeks ago.
Lan Brady
>Thanks everyone, it is mcmasters that I was looking for!!!
You cannot beat woodcentral for information.
Thanks again, Lan
Jerry Whitaker
>If you are looking for 1 x 8, Lowes carries them. I think there about $1.25 ea but no shipping......just $2.18/gal gas to go get them.
Loews carries 1"x8TPI for $2
Ron in Drums PA
Re:Tractor Supply, 1"-8 nuts, $1.18 per pound.
Al Crandall --NE of Indy--
Lan Brady
>Thanks to everyone for the help. I use the 1x8tpi from ace hardware on my Jet. I was helping a friend that does not have a computer(of all things). He turns on a Nova Lathe and needs the 1-1/4 x 8tpi nuts. I placed the order last night from McMasters. The 5 pack was shipped this morning.
Lan
Howard Norman-Prescott, AZ
>You have cheap gas. I just paid $2.32 per gal.
Howard
Re:I've used those from McMaster before.
>The face of a few of them wasn't square to the threads, and I had to true up the face before welding the washer to the nut so that the plate wouldn't have a lot of wobble in it after welding. I also trued the other face of the nut and put a counterbore in it so it would snug up tight against the shoulder of the lathe spindle without using a spacer washer. My spindle has a short full diameter section of unthreaded spindle for which attachments must have clearance. By the way, the 4" diameter x 1/2" thick washers with the 1 3/8" hole in them make a great faceplate when welded to the nuts. Order them at the same time and save shipping.
