New WoodChat!
Drilling holes/hollowing questions
Dan Lanicek in TX
>I'm a fairly new turner and I'm making a votive candle holder turning. It's a short face turning with a southwestern shape (rims are narrower than middle). Would you call this a bowl or a hollow form or something else?
This candle holder thingy has holes in the side cut with a Forstner bit. Last night I cut the holes before turning. Hollowing was a chore (and a little scary) but other than one accident where the small scraper caught a hole and chipped the rim the candle holder came out nicely.
I'm now wondering if it would be smarter to drill the holes after I turn the form. Anybody ever done anything like this? One nice thing about turning after drilling the holes was that I could see where I was hollowing and tell how far to go without using calipers.
some hollowing questions: I hollowed using a bowl gouge for the initial hogging out and then a round scraper to reach final thickness and clean up. I have no bent scrapers so the underside of the rim was a little rough. It took a while but I got it done. Is there a better way/tool to do this? Do you sand the inside of hollow forms? If so, how?
Re: Drilling holes/hollowing questions
Ron in Drums PA
>I've done a couple of tee candle holders and I call them tea candle holders. I just drill a 1-1/2" hole with a forstner bit, then clean up the bottom.
Are you using some type of holder for the votive candle other then wood?
>Dan
I have a friend who used to turn these forms all the time. He would mount a burl offcenter so he would end up hollowing through the burl on one side. This left a large natural edge hole and was really nice. He did it all with hollowing tools.
I've done something similar when demonstrating hollowing. Drill 4 holes in the sides and then hollow. The students can see how the hollowing is progressing because you can see the tool through the spinning holes. It also throughs out the shavings so you don't have to stop and clear them out.
Dan Lanicek in TX
>Yes, I make the top and bottom wide enough to fit a glass votive candle holder. I scrape a small recess in the middle of the bottom to fit the glass holder. I may play around with making smaller tea light holders as well.
