How to tell if your bearings are bad?
Mike Rubes, Apex, NC
>Hi all,
I realize that this may fall into the category of questions like "how do you know when your gouge is dull", but I think the bearings on my Jet Mini may be going.
How can I tell for sure that they are or aren't?
Here's what I know.
When I run the lathe, I sometimes get a clicking sounds coming from the headstock.
When I remove power and take the belt off the pully, I can spin the spindle and it doesn't make any noise. Very smooth, very quiet.
When I put the belt on the pully (I've only tried this on low, 2 and 3rd selection) and let the lathe run without tightening the motor clamp, it runs fine. Very smooth, very quiet. When I put a little pressure downward on the motor and then clamp it down, I get the click click click, even when spinning it by hand.
I've noticed that there may be a very slight upward play in the spindle. Sometimes, when hand sanding, it feels like the piece "clicks" up a little as a put pressure on it to sand. I have grabbed the spindle and tried to move it up and down by hand, but I cannot replicate the "click" I sometimes get.
Should I not be applying any pressure before I tighten the lock? When I don't apply any pressure, the lathe is far too easy to stall.
Any ideas or things I can try?
If it is the bearings, do I need any special tools to replace them? I've heard mention of a press, but I don't have a "press".
Thanks,
Mike
Oh yeah, the Jet Mini is 3 years old last month. I've turned 150 plus bowls/vessels of various sizes on it. Some have really stretched the 10" swing, others have been candlesticks. I have replaced the belt about 6 months ago.
