New WoodChat!
Separating a hot-glued turning
Mainebowlman
>After finish turning the bottom of a piece, I'd like to reverse it and hot glue it to a waste blank. Later on, however, I want to be able to remove it from the waste blank without using a parting tool.
Has anyone found a solvent or a procedure to separate a hot-glued turning from the blank?
Jack (in the Mud)
Re: Separating a hot-glued turning
Mark Kauder, Phenix City, AL
>Heat Gun.
Mark
Mike Schwing from Md.
>Other than the heat gun mentioned, a light/medium tap with a deadblow hammer almost always works, without damage to either the waste block or workpiece.
Thanks for the suggestions
Mainebowlman
