New WoodChat!
Thinking of candy at the lathe
Ken from SW WI
>Must be the kid in me! I've always had a sweet tooth, good thing I still have most of them at 51.
This is 3 1/4" diam. and about 6" tall, sanded to 1500 grit and a wipe-on poly finish.
Supposed to be a suction fit, but after a week it became quite sloppy :-( No warpage whatsoever, just shrinkage of the body.
Has anyone ever tried adding about 1/100th of an inch of wood to a lidded box joint?
Re: Thinking of candy at the lathe
Re: Thinking of...try again
Ken from SW WI
>maybe the pic was too large? The preview worked--(?)
Yum!
Carole in VA
>Makes me want to pop it into my mouth!
Robert Cox
>Another, localized, coat of finish?
Ken from SW WI
>If you see a dead spot, you've got sharp eyes ;-)
I'm gonna put another coat or two on, all over. This was only two thin coats, wiped on with the lathe spinning.
Re: Yum!
Ken from SW WI
>I promised Mike Schwing over on WoW I'd make a chocolate one, not sure if I have any suitable walnut on hand though. Sooner or later! ;-)
