New WoodChat!
THE WOODRAT IS BACK!
Ripchains
Ripchains
Ripchains
tdaniel
>I started a new thread because the other one was so far down the list that some may not have seen it. For turners, the only "ripchain" we should use is the skip-tooth or a standard chain. We should NEVER use a ripchain that is designed for an Alaskan sawmill. With these sawmills the chainsaw is held in a frame and the log is sawed from one end to the other with the saw at 90 degrees to the log. When we rip we usually do so by laying the log on the ground and sawing with the bar running the length of the log section, not 90 degrees to it. As Mark mentioned, don't even think about a Granberg ripchain for cutting turning stock. With any chain serious kick-back can occur anytime that less than 2 teeth are engaged in the cut. Small branches should not be cut with a skip-tooth chain for this reason. For the typical turner the standard chain is all you really need. If you do a lot of blanks from big logs a skip-tooth will save you a little time but it is best to have a saw dedicated for this purpose so you won't be temped to cut a small branch with a skip-tooth chain. If there are any remaining questions please post them as this is potentially a dangerous practice and we don't want anyone getting hurt because they didn't understand what we were talking about.
Thanks
TD
Re: Ripchains
Re: Ripchains
bill Crommett in seneca
>T.D. Said it well ! I once knew a professional arborist with a nice scar in his right eyebrow and right cheek with luckily no eye damage. He was lucky, but he got careless and worked after he got tired. He has been a real inspiration to me. (working with my seventh chainsaw)
Re: Ripchains
FROE
>To add to the safe procedure stated by TD, many times, when ripping a billet for bowl blanks, you don't need to rip the billet the whole lenght, all you need is to score a 1/4" or 3/8" line at the end grain and then put down the chainsaw put the froe in that line and whack it with a maul, presto! of course some woods wll be contrary and the froe will not do the job, but any piece with straight grain must likely will split easily.
$0.02
Jorge
Re: Ripchains
Re: Ripchains
Rick in Colgate, Wi
>Thanks for the follow-up TD!
