New WoodChat!
200+ woodworking book reviews
Live Center *LINK*
Live Center *LINK*
Live Center *LINK*
Sean Troy
>Hey all, the live center that came with my Powermatic 4224 is freezing up. Any suggestions on a fix? Can it be cleaned and if so, with what? Thanks, Sean
http://www.desertwoodturningroundup.com
Re: Live Center *LINK*
Get a Oneway! ;>)
Paul Porter in Phoenix, AZ
Re: Live Center
Chris K. in MD
>Sean,
Is is like this one? If so You can very carefully try to open the brass part with a spanner (has to prongs to put in the two holes) I am not sure if its under alot of compression it is likely its under some with at least a wave washer to take up any play. Then you can replace the bearings. Please be careful if you try and let us know.
Regards,
Chris
