New WoodChat!
A55 Smoothing Plane
Tricks?
Tricks?
Tricks?
Ruth in S.Cal
>What's the trick to stop/reduce the dust sticking to nicely cleaned goggles or face mask?
Re: Tricks?
Re: Tricks?
rprevett
>I've had good luck using used anti cling dryer sheets.
Re: Tricks?
Re: Tricks?
JamieDonaldson
>I recommend misting a clean cotton cloth with ArmourAll,then wiping face shield, glasses, anything that you need to see thru. Even keeps CA glue from sticking quite so well!
Re: Tricks?
Re: Tricks?
Ruth in S.Cal
>Thanks...I'll try anything!
Re: Tricks?
Re: Tricks?
Ruth Niles
>I use Pledge (or any brand) spray wax, cleans them beautifully and demagnetizes the glasses so dust doesn't cling. And you can polish your work table at the same time! : )
Re: Tricks?
Keith Tompkins
Re: Tricks?
Keith Tompkins
>Jamie is right! I have been using his suggestion for almost a year...it works.
Re: Tricks?
Only used sheets. New ones smear.
Garrett in Victoria
Re: Tricks?
Re: There are no tricks
Duane C.Leach
>There are no tricks in woodturning... Just skill and good technics.
Also go to a plastics store. Most will have a spray cleaner that will both clean and fight fog and dust.
Have fun turning.
Duane
