New WoodChat!
tail stock chuck adapter
Ruth in S.Cal
>Has anyone used this product from Packard? Mikeincapemay sent me the link ....my tpi is 1/14 x 8 and so I can get a wine bottle stopper chuck for a reasonable price. Given that I would only be turning stoppers, what are your thoughts on using this in teh head stock and then getting the $10 bottle stopper thingy?
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=112830D&Category_Code=
Re: tail stock chuck adapter
Richard Allen
Richard Allen
>It would likely work. A better solution is a headstock spindle adaptor.
Spindle adaptor
The Packard tailstock adaptor is made of soft aluminum. There is almost certinaly a little runout.
The bottle stoper chuck is little more than a screw chuck with a 3/8" bolt for the screw. You could mount such threaded stock in a jacobs chuck or in pin jaws of a scroll chuck to get the same sort of bottle stoper holding.
Stuart Johnson
>I use the 1 -1/4 x 8 one regularly for centering segments. It is not meant to be used under power so certainly shouldn't be used for adapting a chuck.
Re: Sent too soon
Ruth in S.Cal
>Stuart, thanks so much! I had no idea these mandrels were on the market. They are just the ticket.
Re: Sent too soon
Stuart Johnson
>Ruth, You might want to give them a call and talk about it. I don't have one and don't know if it has morse taper or is held in a Jacob chuck.
thanks, will do!
Ruth in S.Cal
