Corian Pens
Julie
>Hey you pen turners out there. How about a little help with corian? What do you use to cut the blanks? What is the best way to glue up blanks to not have a glue line, How do you finish them?
THanks
Julie
Corian Pens
Julie
THanks
Julie
Re: Corian Pens
Fred L. - North Carolina
>1. Bandsaw with fine teeth.
2. Like for angles: Cut both pieces at the same time so you get the same angle. Fine teeth, very fine sandpaper glued to a block.
3. Sand all the way to micromesh 12000. Renaissance Wax if you want.
Fred
Thanks Fred
Julie
