Sanding Pad
Sanding Pad
Sanding Pad
Marc Phillips
>My new 2" sanding pad I just bought came unglued... literally..
There's 2 seperate pieces of foam, one fairly firm one and then one that's a little softer, then the velcro pad... the glue apparently failed between the 2 foam pads...
What kind of glue do you think they used at the manufacturer to originally adhere these 2 foam pads together?
Contact cement?
I'd like to repair it if I can... Steve already sent me a replacement, and I'll just pay him for the new one he sent if I can successfully repair the one that broke... otherwise I need to just send it back to him...
Thanks...
Marc
Re: Sanding Pad
I used spray on adhesive.
Al Crandall -Pendleton, IN.-
>My Sorby Sandmaster came apart shortly after I bought it, and I used the spray on adhesive which I bought to attach the 12" sanding discs to my Delta sander. The instructions said to spray one side for a removable attachment, and both sides for a permanent attachment. I sprayed both for the Sorby repair, and it is still holding just great.
Re: Sanding Pad
Re: I used spray on adhesive.
JamieDonaldson
>You need a pliable join and contact cement like Goodyear Pliobond or even Gorilla glue. Apply to both surfaces and wait until it is mostly set before touching parts together- make sure its aligned properly because you don't get a second chance!
