Double Wishbone Stretcher Tables
This project began with the addition of a “sun room” to my daughter’s house. She has a lot of greenery which led to a request for tables to set plants on to go in front of each window. The tables would have tile inset tops.
Some time ago I made her a desk and employed an arced stretcher to make it possible to slide a chair under the desk.
She asked if a similar arced stretcher could be used in these tables. This feature turned an easy table construction into one more fiddly to make.
I got one into the clamps last night. That is a lot of joints so I used liquid hide glue. Accurate M&T joints lead to a table coming together orthogonal. Diagonals are less than a mm different in length.
The difficulty in making the “double wishbone” stretcher is first laying out the dovetail joints and then making numerous saw cuts accurately.
One has to decide what to use for a reference surface and if there isn’t one there temporarily add one. Every aid I could think of was used to keep track of what was waste and what was to be left and what went where during assembly. Prior to assembly I sanded a key label off a piece and had to do another dry assembly to be sure of what went where.
In the end the joints that show came out well and the one that don’t acceptable.
Re: Double Wishbone Stretcher Tables
out of clamps
I am pleased with the proportions of the various elements. We spent considerable time mocking up these elements but this step does not guarantee success. I can't bring myself to mock up a whole table to see how it will look.
tile
Re: out of clamps
John Pappas
The stretcher design is quite eye-catching. As for the tile layout options, I tend to like the second arrangement a bit better.
Clint Searl
Nice design
Re: out of clamps
Last I heard design #2 was going to be used. I saw it in person and it looked good to me. Daughter was a dual art major so I am confident she will choose wisely.
Green with cherry is not a choice I would have considered. But I had an artist pick art glass for the corner cupboard I made a while back and green was the primary color of the glass she chose. Ditto for the tile- green and cherry. So if you are matching color to cherry someday, consider green. (I don't know squart about these things and defer to others)
Re: out of clamps
Brad Chenoweth
Really nice piece, Bill. I do have one qeestion - wheres the sock drawer? 😁
Re: out of sox
William Duffield
Since they're intended to be plant tables, the closest analogies to sox that I can think of are Nepenthes (epiphytic pitcher plants). Of course, no sox drawer is needed, since these are intended to be displayed.
https://duckduckgo.com/?q=nepenthes&t=newext&atb=v273-1&iar=images&iax=images&ia=images
Maybe a new twist to the Cinderella glass slipper story?
Re: out of clamps
Steve D, in CT
My kitchen is cherry with green granite. The red and green accentuate each other.
I like the table frame, especially the catenary curve ;)
