Air dried or kiln dried query?...
John Aniano in central NJ
Hello All,
I'm making some replacement beech handles for chisels and I have the choice of kiln dried or air dried American beech. Would one be any better than the other? Would one age differently than the other in terms of patina, etc.? Both this AD and KD stock are very straight grained with no knots whatsoever. Similar growth ring spacing too.
The air dried material was split out from a small (10" diameter) green log about 5 years ago and the ~2" rough squared billets were stored 8 feet up in the rafters of our unheated garage. I just fully squared up two billets of the air dried material and they seem well dried.
The AD stock is a bit thicker and would give me some wiggle room to get the handles straight. The KD stock is very close to the finished handle sizes. I think either would work but I'll defer to the collective wisdom...
John
Re: Air dried or kiln dried query?...
Re: identical properties - KD vs. AD beech
Hi Bill,
Thanks, I sort of thought so.
I did take a closer look at the pieces and noticed the growth rings of KD beech had a bit wider spacing than the AD. How much would this influence the properties for a chisel handle?
John
Warren in Lancaster, PA
I would expect the kiln dried stuff to be a little more brittle. This makes a difference if you are making a tapered chisel handle without a ferrule, as was done historically.
You don't need too much extra thickness because when you correct for straightness, either because the tang is a little crooked or your hole is little crooked, that is done in the tapered portion. So the wiggle room is sort of built in with a tapered design.
For old chisels, I usually add length to the chisel handle to make the total near the optimum length. A lot of chisels have lost an inch or two over the years.
Steve D, in CT
Starting with one of each would probably show you any differences in workability. I milled a couple of trees in my yard and have been dipping into that wood on small projects and test cutting. The air dried material has a "smoothness" when cutting with edge tools. Not the surface but the feel of the cut. I don't compare with KD because I don't have it but that could be one of the factors that people describe.
That reminds me that I have to go through my neighbor's firewood for some white oak...
Warren,
Thanks for the recommendation. Yes, these will be tapered octagons without a ferrule.
What would your optimum overall length be for an early-mid 19th century 1" wide tanged firmer chisel? The blade length now is just under 6". I was going to aim for around 11" or 12" overall.
John
Yes, I like about 11 inches. I have some chisels that that are really worn, including some I have used up 2 inches or more myself. In your case I would aim for a little over five inches for the handle; I like to have my whole hand on the handle and have enough left over so the mallet doesn't hit my hand.
Put a little water in the hole for a while before trying to seat the tang.
Properly done there is no reason to suspect KD vs air dry lumber will have different mechanical properties. And the properly done applies to air drying too. Lumber is at its greatest risk of changing properties as the water from the wood cells diffuses away and the lumber begins to shrink. This step can happen too fast whether the lumber is passively dried or dried under controlled conditions. If air drying occurs where the summers can be hot, there is more risk winding up with lumber with undesirable properties than in a well managed kiln.
When a company has $100K of lumber in a kiln it is a good bet the company gives the drying process adequate attention. When we bought from smaller operations we did occasionally get lumber that was dried too fast.
John Jardin
Bill,
Thank you for your experience on the subject and the clear explanation that you stated.
The two goals of drying
1. Get dry
2. Only experience small gradients of moisture content across thickness and width during drying.
Water moves quicker in hot wood than cold wood. Evaporation rate from wood dependent on humidity.
In ideal air drying the wood is not hot, water moves slowly from the interior to surface and only a small moisture gradient is established. In ideal kiln drying the wood is hot, moisture moves quickly to the surface but the evaporation rate is kept small by high humidity in kiln. Again the result is a modest moisture gradient in the wood.
In either situation too rapid drying at the surface will lead to a high moisture gradient in the wood which leads to stress and tension, unstability and cracks due to differential shrinkage.
The advantage of kiln drying is that it is quicker, something of less importance to the hobby woodworker. And, in the kiln the moisture content can be brought lower than what can normally be achieved by air drying, then brought back up to working moisture content by steaming. Steaming relaxes stress and tension. Also, wood "overdried" does not regain moisture content as much upon sitting around waiting to be used. Hence, at least for the first few years KD wood moves less with changes in humidity. I expect air dried wood eventually becomes as stable but I have seen no data to confirm.
Bottom line, properly done, either KD or air drying works fine for furniture. Personally, I used both.
