Re: An easier way...
eliot feldman
I wonder if you could explain this post in more detail. I' not following "bevels on the inside of the box", for example. I don't get, "bevels" on the outside either. For me the bevel is on the edge so you can close up the box a have a clean line. I'm sorry to be so dense.
Re: Re: An easier way...
John in New Mexico
Probably I am mistaking what you mean, I assumed you were talking about making a box where the outside faces of the box sides are not parallel to the inside faces.
Instead you seem to be talking about beveling the top edge, though the reason for doing so and why Bill's jig would not work for mitering such a piece still escape me. No big deal though, I don't have much to say about the box you are talking about, I've never made one.
eliot feldman
No,no. I mean a "regular" beveled edge box. Everything's square. Top is not beveled. The only bevels I have in mind are the two 45 degree bevels for each of the four sides (eight all together.) These would sit vertically if the box is on a table in its normal orientation. These are the bevels that allow the box to come together so no end grain shows. I build a traditional donkey's ear shooting board to shoot these perfectly (as good a "perfectly" can mean here.) And it's important when doing such shooting to have the reference faces and edges of the box sides correctly positioned against the jig. The next post by Jack Dover explains it well.
Do you mean mitered?
John in New Mexico
If you don't mean a mitered corner, I'm hopelessly lost. A picture would help.
If you do mean mitered, the contention here is that the jig Bill posted is insufficient to make a perfectly mitered box because it will not work with imperfectly squared stock?
