Re: wraparound box - re: Shellac questions...
John Aniano in central NJ
Eliot,
If the Behlen shellac you used dried hard, then it should be fine. Shellac that is old or has been stored at too high a temperature or not in a dry environment, can often initially look ok but will take a long time to dissolve (multiple days even with additional heating) and may not dry to a hard film. It usually is a bit tacky when "dry". In my shop, my mixed shellac polish lasts 1.5 to 2 years. After that, it won't dry properly and seems tacky, so I know it's time for a new batch. Plus, I date the bottle so I know when it was made, or check my notebooks to see.
I'm sure the Behlen product is a good one as long as it's been stored properly. Ditto for any other shellac flakes. Might be a good idea to pop a desiccant packet in with the dry shellac flakes to keep moisture at bay. I've not tried this, but I might...
FWIW, I buy my shellac from Wood Finishing Enterprises https://woodfinishingenterprises.com and Kremer Pigments https://shop.kremerpigments.com/us/
I'm just a satisfied customer. I've bought from both vendors for decades.
John
