Strop Adhesive Questiom
Ron in Sterling, CT
I have obtained a 4" x 10" piece of leather. I am going to glue it down to a piece of 1/2" MDF. What do you use, or recommend for an adhesive. Also I assume that I glue smooth side up. Do you agree, or disagree? Thanks in advance for your input.
Ron
Re: Strop Adhesive Questiom
Jack Guzman from Maine
Barge
Barge leatherworkers cement or liquid hide glue. I imagine just about any woodworking glue will work.
Barge/contact cement is probably best
David Weaver
...but I've used hide glue and tite bond and never had any of them let go despite frequent oiling.
William Duffield
I would not use MDF as a substrate. I think Baltic Birch would be a better choice.
Barge cement is a good choice, but not necessary. I've glued stops down before I obtained my first can of Barge, so I know other products work well enough. However, I don't remember what I last used. It may have been liquid hide glue, or epoxy, or Titebond I, II, or III, or even 3M Super 77 spray adhesive.
I'm not sure that even Barge would work well enough to attach a leather pad to a steel holdfast due to the very strong lateral stresses involved in setting and releasing the holdfast. Does anyone have an adhesive that works well for this application?
contact cement ...
David Weaver
which is barge, right? sand the pad of the holdfast if needed and give it adequate time to dry.
I use "shoe goo" to hold on two aluminum angle pieces in my metal vise and then often tighten things to "lifting a 400 pound bench" end off of the ground to get the vise loose sometimes. The glue surface between the two isn't exactly ideal and I generally haven't had to refresh the glue more than once a year.
If the piece does ever come loose from the hold fast, it'll take a minute to re-apply two of them.
Same with the face of my wood vise - just shoe goo.
But I've never had any type of strop come loose even though I oil mine heavily. The only issue I've ever had is leather that's porous using titebond - if the glue makes its way most of the way through the strop, there will be hard spots. I did this with old junk leather and the only fix for that is the garbage can.
That's my only warning - if the glue is a type that will soak into leather deeply (like a water based glue) don't use so much that you end up glue sizing the leather into a solid block.
AlanWS
Hot hide glue works well, both for attaching a leather strop to, in my case MDF (it's remained flat and stably adhered for at least several years,) and for leather to steel on holdfasts. After about 5 years, one of the 4 holdfast pads did come off and needed to be reattached.
Paul in NJ
Hi Bill,
Poly-urethane glue (Gorilla glue) has worked great on my holdfast. It has been the best, in my opinion, for gluing dissimilar materials. Don't bother wetting the pieces with water as per directions, there is enough humidity in the air. It foams less without the extra water.
regards,
Paul Dzioba
Re: I wouldn't use
Paul in NJ
for a strop. Hide glue or titebond is fine.
