Need some help
Need some help
Need some help
Hank Knight
I'm going to ship three saws (two miter saws and one panel saw) to Matt Cianci, the SawWright, for sharpening. How do you ship saws? I have no idea how to package them for safe shipment. I would appreciate advice from those of you who have shipped saws successfully.
Thanks.
Hank
Re: Need some help
Re: Need some help
David Weaver
saws alternating ends with styrofoam between them so that there is no tension on the blades.
I once received a saw lot from MJD tools and they'd "pointed" the saws all in the same direction and tied them together tightly in the middle. Every single saw retained memory of how they were tied together with the plates almost touching and the handles fanned apart. Only the one lucky enough to be straight in the pack stayed that way, the rest needed to be hammered With hammering comes some risk of unexpected tension effects -it's to be avoided if possible.
keeping the saws all straight and immobile will be best. There's no need to be dainty if you don't have styrofoam given how tough spring steel is, but do something to make sure they aren't bent or can't end up bent in the pack, else they'll retain some memory of any significant bending.
It'll lighten the load on matt if he doesn't have to deal with that.
Re: Need some help
Re: Thanks, David!
Re: Need some help
Re: Need some help
Wiley Horne
I have shipped multiple Japanese saws which are delicate of course (when run over by a forklift, for example).
Agree with everything David said. Couple of minor additions:
1. If the styrofoam between blades leaves the handles in mid-air, support them with something, so they have no degrees of freedom to move.
2. (optional). Consider a package stiffener, so that the saws aren’t taking the bending load when the package gets thrown around at the airport.
Wiley
Re: Need some help
Re: Need some help
I would sandwich them between something stiff, Masonite, thin plywood, etc. In fact make a wooden box from thin plywood.
Re: Need some help
Definitely the best!
Re: Need some help
Re: Need some help
William Duffield
Some professional advise from Mark Harrell and Pete Taran:
http://www.badaxetoolworks.com/packing-a-saw-for-shipment.php
http://www.badaxetoolworks.com/build-great-saw-shipping-box.php
http://www.vintagesaws.com/library/sawbox/sawbox.html
Re: Need some help
Re: Need some help
E Phillip Smith
Does the sharpener need handles to sharpen. If not take handles off, put edge protector on teeth ( thin strip of wood with slot to protect teeth), dead pack with stiffener between blades (1/4 plywood, Styrofoam, etc.) pack and ship. They take a lot less space without handles.
Re: Need some help
Re: Need some help
William Duffield
Good advise. However, there are a couple of pitfalls with that strategy. Removing and replacing the handles of older saws may require a slplit nut screwdriver, which must either be homemade or purchased at a high price. Lie-Nielsen's for exmple precisely fit their saw nuts, but not necessarily old Disstons. Another issue is possible damage (splitting and splintering) to the handle wood while removing the saw nuts. The nuts often driven in below the surface of the handle, and the wood either expanded or stuck to them with finish.
Re: Need some help
Re: Great Advice! Thanks, Everyone.
