Installing profiled case facing molding
I am making furniture for a granddaughter’s bedroom. My case pieces are usually faced to hide the dovetails that hold the case together. She chose a bull nose profile for the edge facing of her case pieces. If the facing is profiled the intersecting facing must be mitered as shown in Picture 1.
The divider locations in the vertical molding are going to be marked, this piece removed, the vee’s cut out and then returned to the vertical face to be glued to the case. For the vees to line up the molding must be returned to exactly the location where it was marked. This task is accomplished through the use of locating pins, snipped off brads.
Four brads are driven into the edge of the case and then the heads snipped off, leaving about 1/8” sticking up with a sharp point. Picture 2.
Whatever size brad is 0.040” shank works best for embedding into the facing to make a locating hole.
With this facing piece temporarily in place the location of the intersection dividers is defined by scoring the vertical molding with a chisel or marking knife, Picture 3.
The vertical molding is removed and with the aid of a vee block, the mitered notches are cut out roughly with a saw and pared to final size with a chisel. Pictures 4 and 5.
The molding is returned to the case and glued in place, Picture 5.
Finally the divider facing is cut to size and installed. One end is mitered and put in place on the case, overhanging the other end of the divider. The required length is marked with a marking knife, in this case one made by David Weaver, Picture 6. The arrow indicates the location of the mark defining the base of the vee.
This piece is cut to length with a miter sled using these knifed marks as a guide, Picture 7.
Fine adjustment to length is done on a mitered shooting board, Picture 8.
The miter angle is adjusted as needed by a “room key” shim. Finally, the divider facing is glued in place. Picture 9.
Re: Installing profiled case facing molding
Thanks for a great tutorial.
Wiley Horne
This is a most clear and well-illustrated tutorial. A couple of wuestions if you will:
1. Are there other traditionally used profiles that can be used? What are the choices?
2. What is the intended use for the very shallow opening at the top?
Tx, Wiley
Charlie
Beautiful -- clean and precise.
Chester County
pull out shelf requested. common on desks
Jack Guzman from Maine
veritas saw
I'm talking about the small saw in picture 4. I've seen that saw in other of your posts. I have that saw and love it. It is more useful in my shop than I expected.
Oskar
Very nice Bill. good work and thanks for posting!
William Duffield
The half round profile is also used extensively in traditional Chinese furniture. Foor exaple, reference "Chinese Domestic Furniture" by Gustav Ecke. In general, any symmetrical profile will work.
