Coordinated Set
Coordinated Set
Coordinated Set
David Weaver
thus far, I've been making the chisels without paying that much attention to one being similar to another. Which makes sense when you're making them freehand.
But I figure now that I have a large supply of files (so not dealing with some being thin or narrow or whatever), I'm attempting to make a few sets that look like sets.
Still just with the bolster shrunk (i'm not convinced reading around that forge welding the bolster is a great idea if the high heat source is heavily oxygenated - the bolster gets welded, but I may be burning the steel involved and making it weaker vs. forge heat being attained in a coal forge in the center above the oxygenated part of the fire. I don't have a coal forge and won't because the chimney is on the other side of my house in a finished area).
All will be handled soon.
Re: Coordinated Set
Re: Coordinated Set
Bruce, a MN Galoot
Nice! That’s an impressive set. Do you know how many hours of work you put into it?
Re: Coordinated Set
Re: Coordinated Set
David Weaver
Thanks, Bruce - I think somewhere around 2 hours a chisel total for chisel and handle.
Intermittently, though, as some of the things like sawing the old files (still do that by hand) and hammering, you can do bits at a time but you can't do it for an hour.
A coarse belt on a belt grinder helps greatly in wide flat work, etc, and on long parers where the chisels aren't that stiff (especially before heat treating) and filing heavy amounts isn't very easy.
Re: Coordinated Set
Re: Coordinated Set
Bill White
Sure look good David.
Re: Coordinated Set
Re: Coordinated Set
Oskar
Very clean work. Looks fluent. Really like the black surface and overall simple look.
Well done
Re: Coordinated Set
Handles turned
David Weaver
I figure I make the handles a little bit big, but that makes them a lot more comfortable to push.
Re: Coordinated Set
Re: Handles turned
William Duffield
If they're comfortable for you, they're not too big. One should not model one's own tools on model parameters decided by the MBA in the corner office who spends most of their time contemplating stock options.
Re: Coordinated Set
Re: Coordinated Set
Steve Voigt
Those look terrific, Dave. Well done.
Re: Coordinated Set
Re: Coordinated Set
Scott Lipscomb
Those look great, and I apologize if you covered this, but, how are you welding the bolsters?
Re: Coordinated Set
Shrunk.....
David Weaver
these bolsters are hammered on and the last heat after they're fitted they come on hot and are shrunk to the tang after hammering by cooling.
I've forge welded a couple which is the same process but the last heat is high heat and then a quick forge weld. I'm concerned that the oxy/mapp setup that I use may burn the tang steel and weaken it when I forge weld, but haven't experimented.
These are just mild steel with a center hole drilled in, driven hot on to the tang on and off until the hole is stretched to fit, and then the last time they're driven on the bolster is deliberately hot without much work to do so that it can shrink a lot.
If the tang isn't tapered, they can slip a little bit when malleting, especially if there's no ferrule on the chisel to help out. Thus, I try to taper the tang just a little.
Long story short, not as strong as they would be if they were integrally forged, but stronger than no bolster. I think the top part in a coal forge is necessary to get to forge welding heat without much oxygen (the oxygen is burned out below in the fire - but I saw a video describing that part of a coal forge is also an area where it's easy to have forge welding temperature competing with burning, thus a relatively deep forge with high heat above the actual fire is best).
I have no such thing available. I guess destructive testing is in order.
Re: Coordinated Set
Thanks, Steve...
David Weaver
you know how this goes - they get a little better each time. At some point, I'll get them just right and then lose interest. :|
A cleaner picture of these is below. Rafael gave me an apple board that made these nice handles (and 9 more blanks left), so these chisels went to him.
Re: Coordinated Set
Thanks, Oskar!
Re: Coordinated Set
Thanks, Bill!
David Weaver
If I close the loop on these things when I run out of steam making them, and they're subjectively better than the early ones, I'll send you a couple more.
