More parers..
More parers..
More parers..
David Weaver
Not yet finished. Just roughed out on a belt grinder and back flattened on a separate belt sander.
I've got a process figured out for these but will hammere the tangs thicker, narrow and longer and then forge weld a bolster on them as I had a successful mild steel bolster forge weld yesterday. There's not much filing to do on these and making the bolster out of file scrap instead of mild steel will actually make the forge weld much easier.
The spark is so strong with these that grinding them sets off my basement smoke detector even though it's through a closed door.
Jack Dover was probably right, I think these are a lot easier for a guy in his garage to make. The first one took about four hours to make, but these will take less than two per.
Forge welding requires oxy mapp which drives the cost up, though.
Re: More parers..
Re: More parers..
Bill White
Forge ahead.
My humor for the day.
Re: More parers..
Re: More parers..
David Weaver
My confidence is bolstered. I'll keep chiseling away at the remaining challenges.
Re: More parers..
Re: More parers..
Paul in NJ
I really like the chisels you have been making, very nice work. Here is a 1/8" wide chisel I made from a saw file.
I was making small drawers and didn't have a chisel that small. Nowhere as nice as yours but it does the job and holds an edge. I agree that files have nice steel and have made a few knives from them.
regards,
Paul Dzioba
Re: More parers..
nice!
David Weaver
one of the nicest things about making your own tools (to me at least) is that you can just use them without feeling the need to be overly cautious.
1/8" chisel fits into that kind of thing well.
(makes great marking knives, too, and really little thin knives from the small thin files to cut boxes, etc, smoother than a new utility knife blade).
