Pedestrian dovetails
I do like it when a dovetail comes together with the thump of the heel of my hand.
Among the other activities today I got one drawer done. I especially like dong half blind dovetails. I oversaw the tails a bit. It makes digging out the waste easier. This cherry is stringy which makes digging out the waste in the corners of the pin board tedious. Cooperative grain snaps off back in these corners. I had to resort to a skew chisel on this wood.
Re: Pedestrian dovetails
Clint Searl
Clint Searl
How do you know how many tails of what width should be cut? Also, what is the slope on the tails?
not a satisfactory answer
How do you know how many tails of what width should be cut? what looked ok to me. You can't go wrong. In antique furniture you will find everything. However, don't make a tail so close together you don't have a chisel narrow enough to clean out the pin hole.
Also, what is the slope on the tails? Again, what looked good. I measured some and they are about 11 degrees +/-. I saw them free hand to save time so I am not following a marked line. Hence they vary a bit. Not noticed unless you put a protractor to them.
What is important for looks....they need to be the same size. I have a gauge that marks the same width pin hole. It is just a slot in a piece of Lexan.
this tip might help
I used to lay out the dovetails full scale on paper. There is a lot that can go wrong. Until laying out becomes routine I found it did go wrong. When it looks good enough on paper, transfer.
Re: this tip might help
When I have several drawers of the same size, I create a template to mark each.
You can do this for gang-cutting or one-at-a-time (tails take no time at all to saw and clear) ...
