Greaseless Compound - 80 grit
David Weaver
So, I ordered 240 grit greaseless compound to use in a hard felt wheel (it would be better on a leather wheel, but I have no such thing large enough to use and may make one). It's to fine on a hard felt wheel, similar to like a 2000 stone or something.
I solved this with a combo order from mcmaster carr last week (to get a very coarse grinding wheel and a cutoff wheel) by adding 80 grit in with my order. I tried it today on the felt. Very interesting! It will spark off of a hard felt wheel, but the felt doesn't seem to be good at holding on to it. It will also finish a tool to a bright polish, at least an unhardened tool. And it'll do it without taking much crispness off of lines.
I like a deburring wheel to freshen the bevel of knives, but this could be an alternative on a dedicated hard buffing wheel (like muslin) -keeping in mind that if the wheel contacts your fingers, it feels not like a buffing wheel, but like sandpaper.
The only side comment I have is that glazing creates a lot of heat if there is some give to whatever is holding the media. Combine that with the greaseless compound, and you have what smells like burning animals. The oils or some part of the binder in it must be animal based - though it's also partially water solvent (animal based because when the tool being glazed gets warm enough, the fat smells like burning meat - I got in trouble over lunch.... :| )
Re: Greaseless Compound - 80 grit
Other knife making and chisel making omnibus
David Weaver
* I received trizact belts in an order with a buffing kit for the high speed belt grinder. Had them before for a low speed 1x42 kalamazoo grinder and not impressed. Holy cow different with double the width and 2 1/2 times the belt speed. Very practical (ignoring the cost of the belt grinder setup) for a nice even reset of a knife bevel and no harsh grind marks, but despite the gentle smooth feel of the belt, it can create a ton of heat and will burn the tip of a knife in a fraction of a second if not used properly. Not just a little burning, but deep blue temper completely ruined burned in a snap.
(The kit also came with...wait for it, a soft surface belt and four types of buffing compound - not too jazzed about that as the belt is slack and they'll round over corners).
* since making the first knife, I've made two more blanks (one in white rikizai and one in XHP). The first knife, I quenched and then couldn't temper right away. I don't think steel is the same if there's a time gap between hardening and initial tempering. The other two, I'll do over the weekend. I convinced the mrs. that I should have a toaster oven in the shop (with all of the other crap I've bought, you'd think this would make no difference, but she thinks it's a fire hazard. The forge apparently is no big deal :\ even though it can set off a smoke detector. I had to use the excuse of parks 50 for a toaster oven (it'll make the main oven stink, which is true - but I could just remove it before tempering).
As much as the rikizai warps (which is probably exacerbated by hammering it and causing the hard layer to end up a little snaky down the length of the blank), I'll be interested in seeing how XHP does. XHP grinds like crap, though. You can't let it get close to critical, even though it needs to go higher to be fully hardened, it will harden a LOT if it even gets hot and then cools. On top of that, it's full of chromium, so it really shouldn't be residing (even in little bits at the edge) above 800 degrees as that's enough for chromium to wander to the edge of grains and things that made early stainless crappy start to occur.
* making chisels is more fun than making knives. But the high speed trizact belt followed by a buffer has to be about the laziest way ever to completely refresh a curved blade, and the sharpness is otherworldly. I'll experiment later tonight quickly, but I think I could probably get a hair hanging edge in about 45 seconds. This is never really attained hand sharpening a knife. The follow on is you can buff a little longer to remove the apex, be only slightly less sharp and see almost no damage at all. The SGPS knife that wiley recommended doesn't love stones, but it loves this combo.
* dust in the air with a belt grinder is a big problem. However, I have a dust port on the other side of the grinder (which is monstrously helpful if using the wheel and catches almost all of the dust). I've noticed that if I leave the vacuum running on that side, the large dust flies off of the belt grinder into the wall behind me and falls (And it's plentiful), but there's never a visible fog of dust (and no black booger syndrome) from the belt grinder. No rule against still wearing a mask. The vacuum claims 185 cfm. It's probably more like 100 when it has anything other than a brand new filter on it, but it's just enough airflow to create a gradual pull toward the grinder and prevent the fines from the grinder from ever really floating away. I can use this idea when resawing (which can put a lot of wood fines in the air) and doing other things at the bench that create dust -I'd always written off the vacuum as being too indirect and too small to do anything but the reduction of dust in the air (by viewing under a few bright LED shrouded lights in the overhead) seems like 20 to 1 or better.
It's a shame there's no easy way to file and float out a knife instead of belt grinding it. File and float are almost as fast as a belt grinder when used properly (the grinder is faster, but file and float leaves no time having to baby the last bit of shaping, and there's no tool dipping). It's easy to waste an hour standing in front of the belt grinder freehand shaping a knife.
