Rabbet Block Plane or Shoulder Plane
Gerald Doll
Gerald Doll
I lack a shoulder plane. Attempting to build the Chris Schwarz saw bench, with the funky 10* angle cuts, and it became quite apparent that my paring skills suck. All of the legs came out wonky. Apparently, it's time to invest in a shoulder plane. But I seem to recall a post sometime back where someone recommended a rabbet block plane as a more useful tool than the medium shoulder plane. Any advice?
Re: Rabbet Block Plane or Shoulder Plane
Jerome
I don’t like this saw bench design, with tilted legs than gets into the way of the saw and a narrow top that prevents the use of hold downs. I really prefer wider top (30cm) with straight legs. This design looks like bulkier saw horse, which to me have a very different use case.
Anyway, I would recommend you use a chisel with the help of a guiding block, cut at the desired angle, attached to your piece, to provide a reference plane to lay your paring chisel on. This is a common practice and really helps in some difficult cuts at weird angles.
David Weaver
I'm agreement with your sentiments, but a lot of people like the look of that type of sawbench more as shop furniture.
I built my first sawbench out of a 2x12 and 2x4 years ago - it's flat, it took an hour to make with through tenons (made very sloppily, too). I've still managed to cut it but never managed to care.
That said, I get the idea that a lot of people like to make nice shop fixtures for their shop and would be goofy to make chisels neatly out of files and talk practicality.
But I do like a saw bench made in an hour.
David Weaver
I thought there was a post from derek about chisels, but I would say neither of those planes. Especially not the rabbet block.
Chisels are where I'd go from the start, though - mark out the tenons and either cut them dead on the mark or cut them shy and mallet or pare off at the lines. I get the sense that a lot of people buy shoulder or rabbet planes and then create errors that need more glue to make disappear.
a chisel and a slight undercut will be much faster. If I find adjustment needs for angles, I use a float - its slow and doesn't remove endgrain fast (really fast on peeling side grain off), or undercut where the removal needs to occur and use a wooden block with coarse PSA paper glued to it (undercutting inside the shoulder just to make the sanding faster).
Rafael from PA
Rafael from PA
If it's the one with trestle legs, I would think that the legs would get in the way when ripping large boards.
In one of the issues of the Quercus magazine there's an article of a vertical legged saw bench. Here is a pic of it in action, blurred.
cutting notch on one end
David Weaver
It's nice to have a long end on one end of a bench like that for a notch.
Not something I'd go to the trouble of redoing, but would include from the start if starting fresh.
You can use the notch to get a little bit of lateral support on thinner items, or to sit on the floor and cope something (including metal stuff you might not want on your bench) - it's surprisingly handy.
I ballast it with a disc sander that I wouldn't have any other use for so that my son can use it for a bench, but the same sander comes in handy as such if sitting and coping.
I've never fretted for a second about an overcut or when my son rasps into it or overcuts and will make the same thing again when I kill it. It's long enough to sit on and rip wood, too - most of us aren't fit enough to maintain the position that the magazine photo shows for 30 or 50 linear feet of cutting in a shop session.
Jerome
I like my woodworking like my cuisine.
I buy raw, organic and local and I put all the fancy in the making. As a French, I also make sure I have decent wine to go with!
Neither
Gerald, I occasionally use a shoulder plane to tune tenon shoulders, but mainly use a chisel here. I find shoulder planes more useful for fine tuning - sometimes making - rebates, especially small rebates (such as with slipped drawer bottoms).
To create an accurate tenon shoulder, I saw a smidgeon off the scribed line, and then use a chisel in the line. A shoulder plane is used when there is too little to use a chisel (where there is too little reference area).
Cheeks rely on being square and parallel. A plane (of any type, including a rabbet block plane, and especially a shoulder plane) is vulnerable to planing away square. If you need to ensure square, use a large router plane. I do so, and have never needed an outrigger to maintain flat.
Mostly I fine tune cheeks with either a wide chisel or a rasp. I would consider these for more confident workers, and you need an eye to keep all surfaces parallel.
My LN rabbet block plane comes out when I need to level and true up the insides of drawer cases. A wide shoulder plane might not have enough clearance (that is, it is too high).
