#3 plane
#3 plane
#3 plane
Howard Pollack
I have a Bailey #3. I like the size of it, but the depth adjustment has way too much slop in it. Is there a way to reduce that, or if not has any other company, perhaps in the past, produced a #3 sized plane with a better adjustment. I know about the Lie-Nielsen plane. Thanks.-Howard
Re: #3 plane
Jim DeLaney, Austintown, Ohio
Re: #3 plane
Learn to live with the sloppy adjuster.
When extending the blade, leave the adjuster snug against it. Don't back it off after adjusting.
When retracting, observe the 'free wheeling' part, then ease the blade back, then before trying a cut, move the adjuster thru its 'free wheeling' and stop just as it touches the blade again.
PITA sometimes, but it works.
Re: #3 plane
Rafael from PA
Re: #3 plane
Rafael from PA
You could try a different cap iron with a smaller hole for the adjustment yoke.
Another alternative is to fit a strip of metal through the cap iron hole to reduce its size.
Re: #3 plane
Re: #3 plane
David Weaver
glue, solder or pein tabs that fit in the iron slot on the underside of the cap iron and touch the adjuster pawl further down (it gets wider as you get lower on the pawl, so even with the same slot size as you already have in the cap iron, you'll get less backlash).
I'm not sure how free-spinning your adjuster is, but I've never found the backlash to be that big of a deal *unless* the adjuster wheel also doesn't turn that easily. If the adjuster wheel is coarse turning, then it's a nuisance to move it far. If it spins freely, you can pretty much stick your finger through the plane under the adjuster and spin it a turn or two just by pulling the web of your hand to the tip of your finger back out, or pushing in - whatever direction things need to go.
Generally, later planes with bigger wheels work better for this.
Re: #3 plane
Alternate adjustments...
Jim Matthews
Could the blade be advanced with a light hammer?
Re: #3 plane
Re: #3 plane
William Duffield
Jim's procedure is needed for all Bailey design or Norris design bench plane adjusters. (As an aside, the Bailey design is more robust than the Norris.) The better planes have less backlash than cheaper planes, but the lay in the adjustment mechanism is still there. If you tightened up the tolerances to take all of the play out, either the adjuster would freeze up just with changes in temperature, or the price of the plane would go through the roof. Backlash is a feature; get used to using it.
Re: #3 plane
Re: #3 plane
Warren in Lancaster, PA
When I started reading this forum in 2005, I had no idea what people meant when they complained of "backlash". It took a few weeks for me to figure it out. The reason was that I had been adjusting my Bailey planes unconsciously for decades. The last time I would have given it any thought was around 1975. As you say, William, it is of little importance.
Re: #3 plane
Spinning the wheel
Winston
The Bailey-style planes that I have all have adjustment wheels that spin pretty freely. I learned that if I give the wheel a good flick (instead of doing a controlled turn-turn-turn with my finger), it'll spin all the way through the "backlash range," and any further rotation will move the blade.
Not all planes will do this -- some may have gummy wheels, and older ones have smaller wheels which don't have as much inertia. In general, using a light oil might help the wheel to spin freely.
Re: #3 plane
Re: Spinning the wheel
Jérôme
I have used padlock lube I had left, which is not greasy and not a dust magnet. Is that graphite?
Re: #3 plane
William Duffield
Used to be. In some cases, still is. In other cases, the lock lube might be PTFE (Teflon) Both work. Sometimes it is a light weight oil, but depending on the viscocity the manufacturer chose, that may solidify in very cold temperatures, for example in a padlock on an intermodal freight container in a Wisconsin winter.
Re: #3 plane
thoughts on the backlash..
David Weaver
..my favorite smoother has a stamped yoke and pawl, and it has a fairly tasteless amount of backlash. But the wheel spins easily and I also (at least for now) have a bronze LN 4. When I first started, I remember thinking how great the LN adjuster is (it has less backlash, it's smooth and the adjustment isn't abrupt).
Warren mentions not thinking about the backlash. In my case, same thing - I hadn't thought much about it and generally when I'm walking from one end of the bench to the other, I will finagle the wheel while I'm thinking about (or looking to figure out) what to do next. It doesn't interfere.
I bought the bronze LN a year or two ago (could be five now, I don't use it much) to have as a bar to meet and try to beat making infills. The few time I've used it in work, I recognize that it has almost no backlash but the slowness of the adjuster for anything other than the finest of smoothing is really annoying even compared directly to the undesirable stanley that I have (lots of backlash, but once engaged, the adjustment is fast and adjustment on the fly doesn't take so many turns and isn't so intrusive).
Re: #3 plane
Re: #3 plane
Joe Rogers, North East West Virginia
I remember a suggested modification to a hand planes adjuster wheel. I don’t however remember where I read it. The adjuster yoke being smaller than the gap in the wheel is responsible for much of the backlash. It was suggested to twist the yoke to allow the contact to be closer when changing the wheel direction. Fine with a stamped yoke I guess but not a good idea if the yoke was a cast part. Then a suggestion was made to measure the diameter of the yoke gap in the adjuster. There are spiral spring steel retaining rings available for pins that can be sourced with an ID that fit in the adjuster gap. After winding the ring around the wheel the ring accepts the yoke contact in one direction of adjustment and closes the gap in the other by the rings thickness.
The spiral lock piston pin retainer for engine pistons is available in many sizes so that is where I would search first.
Joe
Re: #3 plane
Re: #3 plane
Howard Pollack
Joe- That is a very interesting idea. Thanks. -Howard
Re: #3 plane
Re: #3 plane - Be Careful
Making changes to the adjuster can result in damage to either the 'fork' or the frog itself if you're not careful. The cross-pin for the 'fork' is sometimes a bit hard to remove, and too much force can break off the top of the frog, ruining it.
