Rock Table delivered
I wish these pictures could be posted in higher resolution to show the walnut grain better. The flanking top pieces were perfectly quarter sawn walnut. Daughter was pleased with the result.
The table is for behind a couch and becomes a room divider as well as a place to set drinks. It will serve the function of a coffee table. The original intention was for the rock to become a low coffee table in front of the couch but constraints precluded that choice.
Re: Rock Table delivered
Wiley Horne
Bill,
The top is fantastic! There is figure in the walnut—a rippling sort of effect. I want to say ‘beeswing’, but that’s surely wrong. Does that figure have a name?
Wiley
Better picture
I don't known what to call it beyond quarter sawed. I needed 6/4 for this top to match the rock but the best I had was this heavy cut 5/4. The wood wound up about 1/32 shy of the rock thickness but it will be ok.
I was concerned that this tree had ginormous growth rings which typically leads to homely wood. But in fact it turned out ok.
Re: Better picture
Nice subtle rays in that walnut. Color, too. I'll bet it was air dried.
Air dried color of walnut
It was air dried. Then dried at about 130 F. Finally stained with burnt umber pigment stain. With time the varnish will yellow some and the reds in the walnut will bleach and the result will be wood less reddish brown than what it is now.
Real nice craftsmanship, Bill.
more on burnt umber
All artist pigment burnt umber is not the same shade. Some is a yellowish brown while others reddish brown. To keep some of the reds seen in fresh exposed walnut I search for a tube of artist pigment that has the reddish cast. Art stores have been accommodating to let me squeeze a tiny bit of pigment onto something white.
Burnt umber pigment is a mineral pigment probably composed of iron, and maybe some manganese, oxide. I suppose "burnt" umber is this mineral that has been heated. Heating will make red ferric oxide more or less depending on how much heating. Other combinations of iron, water and manganese will yield yellow or brown or black. Add manganese and the stuff becomes darker, and with enough manganese, black.
These pigments are dug from the earth with the variability one might expect from the various combinations of mineral oxides with location. The result are pigments that span red to yellow to brown and dark brown, further altered by heating.
The advantage of using a mineral pigment is that they do not fade or change colors at all. What you wind up with after staining is what you will have, for the most part, years later. I like that property. None of my walnut furniture has bleached to the light yellow -brown walnut will become without some added coloring, either from stain or finish.
Bruce McCrory
Really nice! Really!
Re: more on burnt umber
TomD
"Umber is a natural mixture of iron and manganese oxides and hydroxides. Used throughout history, it has earthtones from cream to brown depending on the amount of iron and manganese compounds and is totally stable"
" In Burnt Umber, the raw earth umber pigment is also calcinated in order to get darker shades."
The colour was traditionally the shadow colour in a yellow environment. Bill is correct that modern paints tend to the red. You can nock that down with a little green if it is too much for your application. The redish tinged BUs can cause mixing problems for painters, but worked great here.
