edge jointing 25 foot planks *LINK*
Bruce Mack
Watch Louis Sauzedde, a shipwright, joint 25-foot planks with a #6 aluminum-bodied plane and a modified Skilsaw. Remember, his creation has to float so gaps are not solely aesthetic.
Tips from a Shipwright Sept. 13, 2020. YouTube.
https://youtu.be/0le4e9KgmlU
Re: edge jointing 25 foot planks *LINK*
When my uncle built a boat, as I recall, there were spaces between planking that were caulked after the haul was laid up. The thought of making a "glue" joint that long doesn't consider the impossibility of keeping a piece of lumber that straight under the influence of gravity and humidity.
Bruce Mack
Quote from one of the viewers "This young man has over 500 years experience in woodworking under his belt. The methods he employs to gain accuracy in his work are fantastic, any woodworker viewing his techniques will be better for the experience." I agree.
Douglas Brooks on Japanese boatbuilding *LINK*
Bruce Mack
"Another interesting feature of boatbuilding is the process of creating planking with a watertight fit. Using a series of saws, boatbuilders make multiple passes through the seams, a process called suriawase (the term combines the verbs “to rub” and “to assemble”). With each pass, the fit between planks become progressively tighter. Boatbuilders pride themselves on their ability to produce watertight boats without any use of caulking. Only older boats are caulked when they begin to leak."
Louis Sauzedde knows wooden boats and will do what is needed. I'm sure he caulks and uses epoxy/fiberglass as well. His attitude and inventiveness would be a treat in a woodworking channel.
https://www.asianstudies.org/publications/eaa/archives/japanese-wooden-boatbuilding-history-and-traditions/
Rafael from PA
Rafael from PA
A recent thread where a new bevel up plane was out of flat by 1.5 mil was deemed inadequate, yet here we have someone jointing water tight planks with an old plane.
I'm a hobbyist and would like to do the best I can with what I have. When looking for information on what to use or get, I note an attitude sometimes that implies that superior machining, tight tolerances, high end tools, etc., etc. is what it's going to allow you to have better output. This comment is not directed to anyone in particular, it's just something I note when I read the forums.
In my own limited experience I find that sometimes that is not true, an inexpensive Washita stone will sharpen my tools, a well prepared cap iron will smooth all the woods I have worked with so far, an old coffin smoother will produce very good results.
The lesson I get from this is that skill is more important than how much money you spend on a tool.
Thank you for posting the video Bruce.
Wiley Horne
That’s really interesting, Bruce. The Japanese entry is too—the idea of running progressively finer saws down the seam. I have a set of 3 boatmakers’ saws from Japan, and have often wondered what their exact use is—this may explain it.
Thanks for posting.
Wiley
Eric Rathhaus
Thanks, Bruce. Great video. Reminds me of Bob Smalser.
His book on the topic is wonderful.
Chuck Nickerson
Also you can get an autographed copy from his website.
Great read on boatbuilding techniques, Japanese culture, and the Japanese apprentice system.
heheh....
John in NM
I don't doubt the guy's skill, but I have to wonder how anyone can have 500 years of experience under his belt! :D :D :D
Re: heheh....
Bruce Mack
metaphor - boatbuilding lore passed by word of mouth from builder to apprentice, generation to generation or.....Sauzedde is one of the ancients :-)
Scarfing saw
CJ in MPLS
Have you seen his custom scarfing saw that he uses to scarf in new planks to old? Terrifying. It is an angle grinder with a circular saw blade. NO guards of any type. While it works well, it is not comfortable to watch.
That he has all of his fingers is amazing. ;)
Re: Scarfing saw
Bruce Mack
I have. He is a maestro.
