New approach to half blind dovetails
I was mowing fence lines the other night and in spite of wrap around safety glasses got some "grass" pieces flung into right eye. It was sharp dry stuff and irritated considerable. This AM eye was more irritated and a rash of poison ivy broke out on wrist. Bad news.
Proceeded to keep at dovetailing today with blurry eye. Didn't see saw kerf and sawed off a pin when removing half tail waste. >( Oh well, it is a cheap easily replaceable part. I think I will not tackle the half blinds in the drawer fronts, half blind, unless things improve tomorrow.
Re: New approach to half blind dovetails
William Duffield
Oh no! That's an alternative definition of "half blind." I hopoe you recover soon.
There are alternatives for recovering the drawer side, if it is something more complicated than a straight, flat piece of poplar, or if you are working on repairing an antique. You can cut a slot in the drawer side a bit bigger than the tail and a couple of inches long into the drawer where the tail was attached. A saw, chisels and a router plane or a router with a straight bit work for this. Then glue in a block of wood and remark, recut and refit the tail.
This technique might be worth practicing on a simple sock drawer. :) :) Pulling the tail out by the roots is much more likely to happen on fragile London pattern dovetails and overloaded, swolen drawers.
Good thing they weren't through dovetails!
Frank D. in Montreal
Or that would have been it for you.
Hope you feel better soon.
Or....
John in NM
You could make a pin shaped slug that slides through the tail and into a mating socked on the back.
Probably easier to just re-make the whole piece though.
Hope the eye is better today Bill. I mention that one the next time my wife gets something in her eye (they are debris magnets) - "at least it isn't poison ivy!" That should go over well :D :D :D
halloween
David Weaver
for some reason, this reminds me of jack o lanterns.
Things about the same
Some steroids in the eye abated the poison ivy response, but, my dovetails don't look any better doing them with two good eyes >( If I claim I can cut dovetails blindfolded, ask to see an example. :D
