putting a dovetail on a long piece
I have a "buffet" sort of tall narrow table underway. Three feet tall, row of small drawers across the top, shelf below. The unique part is there will be a spectacular slab of rock flanked by two 4" wide walnut planks for the top.
Conventional construction for a table with drawers, with rails mortised into legs except top tail on the drawer side will be dovetailed into leg.
The rail is near 5' long and when vertical in the vise for sawing a dovetail on the end it will be far above the vice and out of reach without a stool. I can figure out something for holding this piece to saw it, but somebody might have a better way than what I come up with. So, how would you secure this rail to saw a dovetail on its end?
Re: putting a dovetail on a long piece
Sgian Dubh
Why use a vise to hold the piece vertical? Lay the piece flat on the bench top near an edge, clamp it down and saw from above, even if that means finding something to stand on, or even ... simply kneel on the bench to saw, whatever you're comfortable with. Slainte.
Winston
I've done this in the past by laying the rail flat on the workbench, with the end of the workpiece hanging off the edge of the workbench. It probably helped that I used a Japanese saw -- I imagine that the cutting motion would be more awkward with a western saw.
Les Groeller
If I understand correctly the piece would be too high to cut a dovetail if held in a vice conventionally,I.e. vertically? If that assumption is correct couldn’t one just hold the piece at an angle and cut the once side of the dovetail like a hidden dovetail, flip it and then cut the other?
I may have misunderstood the issue.
Curt Putnam
If you have a porch or deck whose rail if sufficiently high, just clamp it there and cut away as usual. YMWV
Bill, the longest board I have dovetailed was the side of my bench. This was 6’6”.
To do this, it was secured at the far end, and then angled across and onto a saw horse ...
The tails were cut at an angle ...
Transferring the tails to the pin board was a tricky balancing act. The pin board was secured in the face vise, and the long tail board perched on top, secured at the other end (of course), and made level ...
Removing the waste was straight forward with chisels ...
Pins first?
Tony Wilkins
I am pondering this problem on a piece I’m planning; it’s basically a box that is 4’ by 18”. Mine is just large enough that it might work but more than likely will be problematic. I had considered trying pins first so that the transfer, (the hardest part in the process for me to figure out with long pieces,) would involve the short end transferred to the stationary long sides.
Thoughts?
Bill, note that the underside of the tail board was rebated. This was quite significantly so because there was no need to have a thick tail board (20mm thick). Make this around 1/4" for your pin board. A rebate makes it easier to align such a long board.
Oh, yes ... this was sawn upside down .. we do this naturally in Australia :)
Duh, some times I feel foolish
I see the trivial solution to the problem. I'll just orient it 90 degree and slope it in the vise. Now why didn't I think of that? Off to the shop to saw.....
Masterly pins, Derek
What, no foreplay?
Jim Matthews
Should you not scribe, soak in extra virgin olive oil and align your Chakras first?
It's almost like you just wanted to get the business finished and get back to your knitting...
foreplay? Proves it!
Tony Wilkins
Y’all enjoy sharpening WAY too much. Lol, I knew it from these threads but there’s the final proof ;) jk
