Weaver Veg O Matic
Weaver Veg O Matic
Weaver Veg O Matic
Monty Bates
My apology for butting in on this fascinating discussion on Unicorn. I have followed Mr Weavers exploits on this forum for a very long time but he has never tempted me to try any of his endeavors. That is until now. Now he is saying I can just go get a rusty old Stanley, clean it up a bit and install a cheap Chinese iron it will produce gossamer shavings. The only thing he didn't say is if I act quickly he will double the offer. Well I am a sucker, I have to try this.
However, there is always a however, his hucksters version requires a great deal of dexterity of his hands. That dexterity is my problem, I don't have it. I don't need the Weaver Snake Oil, I need the Weaver version of the famed Veg O Matic. Insert plane iron, press down and out pops a sharpened Iron ready to use.
Setting aside my attempt at humor my question is there a way to bypass all that free hand work yet still achieve the same end result?
i have a 10" dual speed Grinder/Buffer I have never known what to do with. Is it possible that I could put on CBN or Tormek wheels and then use the Tormek Camber jig to achieve the same results?
Re: Weaver Veg O Matic
set aside your annoying attempt at humor
and ask nicely and you will get a useful answer.
The quick answer to the questions in order are yes, and no. If you really had been following you would already have learned how to employ Unicorn-Lite with what you already have on hand.
David Weaver
I don't mind the humor!!
I wouldn't use one of those giant tormek CBN wheels at high speed or even half speed grinders. I've not had one in my hands, but have an aluminum 6" wheel full width and a narrow steel wheel. They are extremely heavy.
If dexterity is bad, I'd use any grinder to set the hollow and then use a guide to set the bevel at 23 degrees and little dexterity is needed for the buffer. Even if hand control is a problem, find something to attach the chisel to and stuff it into the buffing wheel for a couple of seconds.
I actually thought about this the other day - how many ways could someone make this expensive (that's what was on my mind) and completely detach someone from understanding what's going on (not the topic here, but the machine idea comes up for that). I think the koch system was already capable of indefinite chisel maintenance post grinding, and maybe for a long time, but it's expensive and has the "magic secret" vibe with it and appears that it's being clearanced out of the country now.
So...What could someone do? for square tools, some kind of rest could be made with wheels - grind, hone and then sliding the tool past each stop, buff at the end. perhaps a version made with a flat belt is more realistic - but it wouldn't address the wear on the backs of plane blades.
All that said, I am clumsy - my dexterity isn't that great, but it's been improved a little bit by repetition.
Monty Bates
Perhaps the word Dexterity really doesn't explain my situation. My hands don't always receive the signal from my brain. For instance the simple act of writing my name is almost impossible. So for me to do anything freehand is out of the question and I would never dare use a buffer like you do. Simply to dangerous as I might well push forward when I really wanted to pull back. Obligatory statement, please not one word of sorrow because this is just a bump in the road. There are always alternatives to getting things done and that's what I am looking for.
David Weaver
I'm thinking you can maintain everything in a jig then, and fixture something to a buffer holding the chisel that won't move backwards even if your brain sends an inverse signal, but will move forward a small amount.
If it's slow to get the chisel back out and you buff for a few extra seconds, it won't be a big deal - it takes a lot of buffing to really make things go bad.
two runs of sandpaper with a guide would also be OK for setting the primary bevel and then secondary (or two small belt sanders).
Lotsa variables and habits to unlearn *LINK*
Jim Matthews
This approach works beautifully with chisels (fist time and every time since) but gives me fits on plane blades. I followed DW's explanatory Vidjayo which repeatedly mentions angular momentum and sharp steel can lead to jugular indentum.
I'm trying to shorten the time between "Time to make the donuts" and Bazinga! sharp.
I know it can be done because I have an example on hand.
Doing it myself has proven difficult, and my hands do what I tell them to do.
(Which might well be the problem.)
If you can't swing a freehand pass on the buffer, can you clamp the blade to a wood "paddle" and raise that to the wheel?
Keeping a grip is hard enough without crossed wires complicating things.
http://www.veritastools.com/Products/Page.aspx?p=128
