microscope images
kenneth hatch
How do you clean the bevel of your cutter so there is no gunk showing in the photo?
microscope images
kenneth hatch
Re: microscope images
Winston
First, I wipe the blade with a piece of paper towel. Then I swipe the end grain of a piece of wood across the edge of the blade. With a narrow piece of wood, it's easier to slice deeper into the end grain so that the wood cleans off more of the blade.
ruin tshirts...
David Weaver
one wipe doesn't do it, sometimes five doesn't.
if you're photoing the back or bevel, make sure you keep your fingers away from the edge after wiping, and if you're wiping, make sure the opposite side of the blade or the tool edge doesn't have oil - if it does, you'll end up getting a little on whatever you're using to wipe and it literally will be enough to make the edge look like it's filthy with oil.
kenneth hatch
Thanks guys, I'm new to microscopes.
ken
