preparing your own pigment stain; application
At one time I knew the chemist at General Finishes and he told me they prepared their pigment stain by mixing pigment into what they sell to the consumer as "Pre-Stain Wood Conditioner". They would mix the pigment with equipment that would grind the pigment and disperse it. We have a way to get to the same place.
Mix 10-20 weight pr cent artist oil pigment into the pre-stain. For walnut I use just burnt umber. However, it is a ground up oxide of iron and it can range from reddish to yellowish depending on the brand. I prefer the reddish toned burnt umber for walnut. The art store may let you squeeze a bit onto white paper to see the tone. Because it is a mineral pigment it will never change color.
The stain is applied with a rubber like shellac. Dab into the stain, bounce rubber a few times on the jar to distribute into the rubber and rub it on. Applied this way one can control the amount applied to some extent and a little goes a long way. About 5 mL did this project. I think it was mixed 12% pigment.
Re: preparing your own pigment stain; application
Robert Hazelwood
Thanks for sharing. I like that approach.
Easier than anything else I tried...
David Weaver
..based on our prior discussion on here, I used artist colors instead of the straight pigment (but have both on hand now), and used another stain instead of conditioner just because of experimentation. Mixing pigments with stain or artist colors with stain totally overpowers the original stain, but starting with conditioner is a better idea if it's on hand.
I also applied it with a pad. The pigment density is so high, and the uniformity of application due to the small particles is so good that if too much gets on a surface, the excess wipes right off. It doesn't penetrate unevenly and spoil the look.
Unless "rustic" is the goal, I"ll never color wood with anything other than artist colors of micronized pigments again.
