Before the unicorn - similar edge with stones
David Weaver
Looking through some of my chisels last night, I found this one from a set that I set up a couple of years ago. I never used this particular chisel after setup, but the rest I've used a bunch.
It's just an old stormont tang chisel with its brand stuck out with a line (as in, it's a second of some sort).
If someone has an aversion to buffers, this is how I think beginners should sharpen chisels. It's a primary grind that's not too steep, and then just as the unicorn is done, the secondary bevel is up just off the primary, and a fine stone strip on the edge, probably around 30 or so.
The point of it is that the fine stone work is targeted and precise. You remove a little from the edge with a slow fine stone and there is visible evidence that you have.
It eliminates the need to set an angle on the grinder or use any guides at all, and the fine stone can be hard and precise instead of fast. Sharpening cycle time is enormously reduced and success is high without having to have great technique.
It also eliminates the problem that I see with most single bevels in practice, which is the failure to get the finest stone work thoroughly completed at the edge.
But the buffer just makes it easier yet to complete work, it's sharper, and the edge is more durable.
Re: Before the unicorn - similar edge with stones
keen eyes will..
David Weaver
...notice the tiny damage at the edge of this chisel. I think I may have set up and sharpened the entire set of 8 in about a half hour.
That wouldn't be there once the chisel is in use - it looks like the small final bevel didn't reach the edge, but this could've been 8 of 8 chisels, too, and probably hurried. The picture of the edge otherwise is still a good idea for anyone who ever goes back to the bench and finds the chisel isn't sharpened that well.
Despite all of the OWTs about this or that kind of failure that float around the forums (angles, etc, heat failure, new chisel, etc) it's almost always going to be because a job wasn't completed -even if incompletion is too small to see easily.
