Buffer for Unicorn Profile
A friend suggested this possibility. Mount a buffing arbor in the lathe. Most of us have a lathe that sits idle when we are making drawers.
Safety...
David Weaver
...I mentioned a few times now, but safety isn't first in my shop on things like this. I wake up and pay attention when power saws are running, but for most of the rest of the time, i don't.
Two things come to mind, though.
* lathes are awfully strong devices, and right below the buffing wheel is a lot of metal for something to bounce off of. The HF buffer is less than $40 with a coupon and I haven't managed to mess anything up on it yet other than the power cord.
* everyone wants to see the bevel of the chisel because we don't trust what we don't see, but this isn't precise enough for that to be necessary. I think working on the bottom side of the wheel the top of the wheel rotating toward you is safest. A catch of any sort just throws the tool downward a little.
plus, when you get a bit of wax from the buffing stick flying around, it doesn't land on a lathe bed.
But a lathe or hand drill or anything will work - the result requires some specification, but the tools needed are all low precision.
Agree on all points
I bought the Harbor Freight buffer for convenience, but $60 was my price. However, had I thought of the lathe I would have started there for evaluation, which is why I suggested it. I can vary the speed on the lathe. Turners buff projects all the time on the lathe. No harm to lathe. Quick way to try it out.
Re: Safety...
John in NM
I've had lowly 1/3 hp grinders rip a work piece right out of my hands and throw it across the room when using a wire wheel or loose buffing wheel. I even once learned the hard way that the <1/4" guideline for tool rests and abrasives is there for a reason - never believed it until I saw it.
So I would say that while a larger machine like a lathe is more dangerous, even a small bench grinder is plenty dangerous on its own (which is part of the reason I like the hand crank buffer I use). Like the drill press, a buffer does not strike us as a horribly dangerous tool as a table saw often does - and we get complacent. I've been surprised and occasionally bitten by my drill press a lot more often than any other machine.
Re: Safety...
1. buffing where the wheel is forcing the tool away from wheel seems fool proof. Am I missing something?
2. I put a foot switch on my drill press after the bit hung in something and created a propeller.
3. Grinders have a lot of stored energy in the spinning wheel capable of being transferred to somewhere else. The buffing wheel is so light it has essentially no stored rotational energy.
The energy....
David Weaver
...is in the fixed shaft attached to the motor. I have a feeling you could throw a chisel like a juggs machine with a buffer.
I'll explain further what I mean about the lathe ways and rests. If the buffer gets something, you'll feel it jerk it, but it probably won't leave your hands.
If it jerks something and throws it into the ways instead of a floor, it may make a sharp turn into some part of you. Tips of knives, etc are going to be more likely sources of problems on the buffer until a habit is made of where they go and how you're oriented with it.
*do not do a knife that folds without a locking mechanism on the buffer until you've got a significant amount of experience.
I buff straight razors on this buffer once in a while - it's not uncommon for people to do that, but that's like a folding knife situation on steroids because the tang is short if the buffer wants it, the buffer can have it. I don't need to be holding to it if it gets launched and the buffer wants to fold the thing shut quickly.
Agree...
John in NM
The motor armature has vastly more mass than the wheels, and there is no belt to slip like a clutch. Granted it is closer to the rotation axis, but I think it is the bulk of the KE.
As to the wheel being grabby, I've not used the kind you guys are using often enough to have a feel for it. I am exceedingly careful with my flap sander wheel though, as it can grab. Probably no one is going to be foolish enough to buff with the edge up on the wheel, as we grind, but you never know. Buffers and grinders are sneaky hazards like the drill press.
The foot switch is a great solution, often seen in industry for many machines. I've formed the habit of clamping things down or to a fence and not use excessive pressure on steel and aluminum parts.
