Does my wheel need a hair cut?
I am thinking this is not the wheel profile, or lack thereof, I need?
Buffed some kitchen knives and the results were impressive. Tomatoes look out.
Re: Does my wheel need a hair cut?
David Weaver
Ignore those hairs. They're showy, but they'll be gone soon enough.
They have no cutting power, even if they're loaded, and can't do any real harm.
Winston
The soft wheel I've been using has a direction to the hairs. If you spin it in one direction, it's like petting a cat the right way; if you spin it in the other direction, it's like petting a cat the wrong way.
I currently have it oriented so it's like petting a cat the right way. When I tried it the other way, the fibers stood up so it looked like what you have in your picture. I don't know if one or the other way is the correct way of using it.
Bill White
I make and use a "rake" made from retired bandsaw blades. Tape 'em together with teeth turned in opposite directions. Touch it to buffing wheel surface to refresh and "DE-HAIR" the surface. Costs nothing but a little time, and sure makes a big difference.
I'm having the same problem
Chuck Nickerson
with a sisal wheel and wondering if I should trim the longest of the hairs.
The vendor has been unresponsive to my requests for information.
Re: I'm having the same problem
David Weaver
They would probably be more easily torched or candled off than trimmed.
I've never noticed them to do anything and eventually they're gone on their own.
thanks
