In regards to wooden planes with double irons *LINK*
Rafael from PA
Rafael from PA
Hello,
In the plane weight thread, David talked about fitting the wedge of wooden planes and the advantages of single and double iron planes.
I found his post very interesting since I have a Mathieson coffin smoother that works really well for me. In examining the plane I noted how well it was made.
The wedge and the abutments are well matched, note the multiple planes cut on cheek of the throat. When new, the fit would have been perfect.
This type of work is so inspiring that I decided to try to make my own wooden planes.
I'm adding a link to an album with more pictures of this plane.
Rafael
Mathieson 8" coffin smoother
Re: In regards to wooden planes with double irons *LINK*
Shavings in the third pic
Jim Matthews
Looks like snake skin!
Rafael from PA
A smoother that needs adjustment??? *LINK*
Rafael from PA
I have another Mathieson smoother, this one has a 2" double iron. It's a replacement, by I. Herring & Son. The chip breaker is original as well as the wedge.
Here is a picture of the tip of the fingers, notice how it goes past the downward curve of the chip breaker? It seems like it could be a clog point. Should it be cut so that the tip of the fingers are above the curve of the chip breaker?
I uploaded more pictures with captions to the photo album.
Mathieson wooden planes.
Re: A smoother that needs adjustment???
Warren in Lancaster, PA
It does not seem as if the wedge fits at all. And it looks like it was cut down at the top end also. I would make a new wedge.
Re: Restoring old planes
Steve Voigt
Hi Rafael,
With the two irons screwed together, hold a straight edge length wise on the cap iron. Take note of where the high point is on the bottom end of the cap iron. The tips of the wedge should ideally not protrude past this point. Since they obviously do, there are a couple fixes.
First, trim the tips of the wedge so they match up with the corresponding ends of the abutments.
If this doesn't fix the problem (likely), it's because a lot of material has been taken off the bottom. It's common that old planes were flattened more aggressively than needed, and your plane could be 1/4" or more shorter than it started out. The obvious fix is to joint the sole and then glue on a new sole piece of the necessary thickness. Drill and saw out a narrow (about 1/8") mouth first, then you can chisel it to match the bed and wear once it's in place.
Before you make a new sole, measure the height of the plane on both ends. It's common for the plane to be much more worn at the toe than the heel, in which case your new sole will be wedge-shaped.
Best of luck with your plane making and restoring.
Finding the answer rather than why not..
David Weaver
As you've seen, if you can find relatively unused planes that were probably made in the mid to late 1800s in England, they are probably the best wooden planes ever made.
I can match them in performance, but I can't better them (when they're refitted and forgiven for a century and a half or more of movement). At least in terms of trying planes, jointers and jack planes - I can make a coffin smoother plane work well, or make one that works well, but a common stanley 4 makes my heart swoon when it comes to smoothing.
When I was on my chase, I found the mathieson, griffits, etc, almost identical in the middle - the little nuances above the wear were related to how the makers cut the waste out of the cheeks (flat facet toward the center of the plane and then forward to the end of the eyes in another facet, or a single cut from the abutments all the way forward.
It takes finding out why something was done rather than trying to find a way to argue against the most likely scenarios. Simply, finding planes in the condition they would've been when this type took over and looking at them.
I had another reason for doing all of the buying - it wasn't to chase ideals and one up anything, it was the realization that if you're going to learn to make tools, and you've made tools before that come in second to tools you've bought for various reasons (studying poor examples or not understanding or executing details), it's worthwhile to spend a few hundred dollars and find the best working examples you can find. The english planes just ended up all being a whole lot less different in design and proportion than I expected they would.
