I just got back from the post office an hour ago. I took the adze into the shop and tried it out on a small bench seat I had partially hollowed previously. The tool is heavier than my other adze that I bought from a british maker. The flat makes a huge difference as does the extra weight. The other adze left a rougher surface and wore out my arm quickly. This one is easier on my forearm muscles. With a little care I can achieve a smoother surface that needs less work with the scorp. The real test will be hollowing a new seat from scratch but I can already tell that this is the adze I was looking for. Nice job Jason.
You can clearly see the differences . The angle of the edge on the lighter adze is too straight for how I use it. To get it to cut well I need to tip my wrist and this causes pain. The edge is also more blunt. It is a chopping tool as it is. The Lonon adze edge is more like a carving gouge. It can slice rather than chop. Also the angle of the edge is friendlier to my wrist.
Jason Lonon is a woodworker as well as a blacksmith. He teaches spoon carving and bowl carving. This gives him the knowledge to create a tool that functions well. He recently posted his intent to create inshaves. He is using an antique inshave and experimenting with the design of a new version similar to the antique. I am waiting patiently for him to offer one for sale.
That adze is so interesting, it got me looking around at other examples. And also inshaves, now that you’ve mentioned it.
One of the differences you see, in both adze and inshave, is whether the blade geometry has a flat—like you talked about on your adze—or whether it’s a segment of a circle. For example, a fellow named Richard Grell, also a Windsor chair maker, makes an inshave with a flat section. Maybe Jason’s will have that also.
