File Handling Tip
File Handling Tip
File Handling Tip
William Duffield
Tool making, not secretarial skills. :D
For 20 years I have been working on improving my methods for installing turned wooden handles with ferrules onto tanged tools, most often files and rasps, but also chisels, carving gouges, marking knives, and turning tools. This is a variation on the old square peg in a round hold quandary. I've burned them in, epoxied them in, strengthened and filled the gap using the split dowel method, drilled multiple small holes at small angles, etc., etc., and so forth. I've also refined my ferrule installation methods and more or less dealt with air bubbles trapped under epoxy poured into the handle hole. Up until now, my best method was to inject liquid epoxy into the hole using a Monoject 412 syringe, but I only get one use out of them with epoxy, and even in bulk they are 50¢ each.
This tip is the final simplification in a long journey. I'm still working on explaining and illustrating it, which I hope to complete before the coronavirus gets me. For now, however, I am just sharing my latest, and perhaps best improvement, which was finally proved experimentally last night.
In summary, the complete process consists of:
- drilling a hole in the end of the handle blank that the tool's tang will fit into,
- selecting a ferrule that will fit the tang,
- making a mandrel from a HSS drill blank,
- gripping the mandrel in a chuck in the lathe headstock,
- mounting the ferrule and handle blank on the mandrel,
- turning the end of the handle to fit the ferrule,
- permanently installing the ferrule,
- optionally turning and polishing the ferrule,
- turning the handle between centers to fit my hand,
- backing off the tail stock to finish the butt end of the handle,
- sanding and finishing the handle,
- pulling the handle off of the mandrel,
- fitting and gluing the tang into the completed handle.
Plumber's epoxy is the discovery that makes this last step, which had been an extreme annoyance, instead easy, quick, and foolproof. This stuff comes in a tube, like grey cookie dough, in two concentric layers, resin and hardener. You cut off as much as you need, kneed the two parts together, roll it out into a worm that fits into the hole in the handle, drop it in, shove the tang in behind it, make sure the tool and handle are aligned, cut off whatever squeezes out, and leave it for about 20 minutes to harden and cure.
I've got about six more files out in the shop waiting for handles. I hope to get a few more clear, illustrative pictures of the process.
Re: File Handling Tip
Don Stephan
Very easy to follow you notes.
file handles
I recall in my grandfathers shop the files all had corn cob handles. Personally I rarely use a handle on a file, only the really big ones I use to sharpen lawn mower blades.
Your suggestion for epoxy is better than the System 3 I have used. The increase in viscosity would make less mess.
Leo Cuellar
Leo Cuellar
My process is similar, but, I use drill bits (from flea markets or garage sales) that I've taper ground to match the shape of the tang. I just chuck the bit into a cordless drill and run it on the side of a stone on the slow speed grinder to shape it into the size I need. Before drilling with the tapered bit, I use a normal bit sized to the small end of the tang to drill a bit deeper(1/2") than the length of tang I intend to sink into the handle to keep the tang from bottoming out, and or splitting the handle when being driven home. I generally use a piece of copper pipe for a ferrule fitted to be tight and also needing to be driven onto the handle. Deburring and chamfering the inside of the ferrule before installation eases the process. I've never needed to use epoxy or glue. If one ever does come loose all that would be required would be a smart whack with a mallet to reseat it. The oldest ones I've done with this method have been in service for 15 years.
A Syringe “Tip”
Raymond in Trenton NJ
A suggestion, not the business end :D
Sir William,
Looking forward to your handle treatise. For files and rasps I prefer removable handles. For some applications I also find then better sans handles. Now, for all other HT handles I’ve made (awls, marking knives, depth drills [for turning], etc) they are epoxy in with 5 minute liquid mix. Judicious amounts and blue tape never made a mess not easily cleaned up with denatured alcohol (isopropyl also works). DA also thins epoxy, used that to fuel-proof the engine and fuel tank bulkheads and compartments on my RC planes in HS.
OK, here’s the tip: flush your syringe with DA.
The first flush, I fill the syringe with DA to clear the majority of uncured epoxy into newspaper or paper towel. After that I pump DA in and out from a couple (few?) oz in a small paper cup. I do this ‘more times than I think necessary’ (never counted :o) I wipe the plunger tip with DA before putting it away. I’ve had syringes last years. I usually can get the syringe cleaned where the epoxied work is getting stiff enough where any blobs are easy to peel off.
Yeah, the syringes are cheap, but I’d rather have it in my workshop than in a landfill. Paper towels and tape are about the only single use tools I’m OK with. Just my preference and two cents.
Be well and talk to you later,
Raymond
Re: A Syringe “Tip”
William Duffield
When I work with epoxy (usually West System) I clean up with acetone. The rubber stoppers in my syringes do not do well with an acetone bath. They tend to swell up and lose their flexibility. In the future when I'm using syringes, I'll try the DNA, because I also hate destroying and trashing syringes.
The advantage of the plumber's epoxy is that it requires no syringe, measurement of resin and hardener is trivial, there is no problem with trapped and compressed air bubbles pushing the tool out of the handle as soon as you turn away, clean-up is insignificant, and you don't need even minuscule amounts of blue tape. I use ProPoxy from Ace Hardware. Note that, like other epoxies, there are warnings on the label about skin and eye irritation and allergic reactions, so I guess I should be using my nitrile gloves when I work with it.
https://www.acehardware.com/departments/plumbing/solvents-and-cements/plumbers-putty-and-sealers/4295622?x429=true&gclid=CjwKCAjwlZf3BRABEiwA8Q0qq-HoMZD8TFja3248tnoWX-Z4ZXdET-k08YLb0_0E7cmYAyssuf1vIxoCeEYQAvD_BwE&gclsrc=aw.ds
Whenever I use a file or rasp without a handle, I'm uneasy about the possibility of skewering the palm of my hand if I accidentally run the file into something that won't give. I understand draw filing the edge of a metal sheet after you have torched it or cut it with snips, but I haven't found a woodworking file or rasp application that didn't benefit from the use of a handle.
Darrell LaRue
As the late great John Lederer said on the Oldtools List:
"Personally I only use prime first growth winter hardened range fed
american hardwood for my file handles."
That's right folks, snip off a bit of tree branch, drill a hole in it, and jam the file in. Done and working.
A contrary opinion here, I suppose, but valid enough for those who just putter in the shop.
Darrell
AlanWS
For small files as are used for dovetail saw sharpening, a wine cork works fine as a handle. For larger files (and sometimes small ones) I turn wooden handles with ferrules of copper pipe or brass fittings, and drill a stepped hole with several bit sizes. For my file use so far, friction has held them in the handles well enough, and this allows transfer of a favorite handle to the file currently in use. Various handles are needed mostly because tang sizes vary.
I'm curious what you do with a file where an epoxied handle would help. All my uses of files involve pushing the handle on.
Syringes with rubber tipped plunger are not what you want for epoxy. By searching for "PP plunger syringe" I found that Grainger Item # 45UC67 is the type of syringe I prefer, with a polypropylene plunger. These are preferred for use with anything other than water. They are stable to epoxy: I buy it in gallon quantities for some uses, but keep a 10 mL syringe full of resin and a 5 mL syringe of hardener to easily measure out the 2:1 ratio in small amounts, though I don't use syringes for transfer of mixed epoxy. The filled syringes are capped by pushing the ends into a hardwood block with appropriately sized holes, which also stands them ready to hand.
These are the syringe type:
https://www.grainger.com/category/lab-supplies/chromatography/chromatography-syringes?attrs=Item%7CAll-Plastic+Syringe&filters=attrs
AlanWS
Gloves should definitely be used with epoxy because it is the sort of thing where allergies can result, and it's a mess. Note that you rarely have an allergic reaction to your first contact with something.
Modifying the viscosity of epoxy is pretty easy, though you might need to experiment a little to get exactly the effect you want. Mixing in additives such as sawdust, silica, or microfibers is useful and gives varying properties to the hardened epoxy.
To get pure epoxy to thicken, measure our both resin and hardener carefully, but mix in only a small portion of the hardener into the resin. (You can also mix a small portion of the resin into the hardener if you want to thicken both.) This will react, leading to a more viscous liquid, and you can let the heat from curing dissipate. Now if you mix in the rest of the hardener (very thoroughly!), you will have a much thicker goo that will slowly harden into the same epoxy as it would have.
The difference between this approach and just waiting a bit after initial mixing is the heat dissipation step. Normally heat generated by cure will both lower the viscosity and speed the cure, so you have no time to work when it gets thicker.
