fluff balls of ash
fluff balls of ash
fluff balls of ash
Slowly selecting and fitting parts for a desk. I'm unsure I am going to like the result, but we need its function and it is a practice run for one for granddaughter. Thought it would be easy but it has turned out to be a fitting marathon. Each leg wound up with lots of holes for lots of pieces attached to it.
Anyway, it will not be stained so I thought I would risk planing the surfaces. I have not had easy success doing anything with ash in the past. Ash can have a brittle texture and be prone to picking out divots with machine or by hand.
In this case a slow growth leg not only planed smoothly, it made these puff ball shavings. I'll save them for granddaughter visit. She turns things like these into all sorts of pretend applications.
Re: fluff balls of ash
Keith Newton
Bill, If you wrap gifts for Christmas or any other occasion, Just brown craft paper with a nice long white pine ribbon around it, then topped off with some of those will delight the recipient with wild expectations.
ash is a tease....
David Weaver
..most bits of it plane wonderfully. Some stuff runs out in really odd directions and planes acceptably .
but no matter how bright the surface is on it (where there aren't pores), it's so interrupted by pores that you can't quite appreciate it.
The shavings remind me of the fries at chick-fil-a
Nice shavings!
Raymond in Trenton NJ
It always struck me as funny that the 'waste' in hand tool work is (to me) as interesting as the work itself. Seems I've never picked up 'waste' from my BS or TS and played with it, measured it, smelled it or inspected it under a loop.
This also seems to confirm my wife's opinion of weirdo. Some people just don't understand.
Oh, nice photo Bill,
Raymond
Re: ash is a tease....
That is what I thought too. The pores made the same pattern. It is mostly why I posted. Never seen anything like it.
cherry...
David Weaver
the other thing about ash is that it'll keep that lattice open a little until fairly thick shavings. There's some english oaks that are like that (really bright shiny surface, buttery wood, interrupted by pores).
Cherry will have that lattice on the very thinnest of shavings, but then it closes up.
Examining shavings is a funny thing. You can have two 1/2 thousandth shavings, or even a little bit less, and tell which one came from a natural stone (the shaving will be less uniform) and which came from submicron abrasives - more uniform, even when thin - due to additional (completely unnecessary) sharpness.
Much of the art of selling snake oil and making really thin shavings at woodworking shows requires:
* careful selection of wood
* wood already has to be close to perfectly level in use
* sharpening (though this is minor, despite being peddled as the culprit for thin shavings)
* willing plane pusher
Audience that thinks they're viewing something very unusual, potentially rare, and useful.
Oh no you dinnit...
Jim Matthews
"due to additional (completely unnecessary) sharpness..."
Heresy!
Re: i diddit......
David Weaver
...i trew down the tauntlet. :O
friend of mine bought the 30k stone early on in my travels in wasting money. He had king 8k, i had shapton cream, he got the 16k and the 30k glasstones "just to see". Having paid as much as $775 for a sharpening stone in the past (not a synthetic), I still look back and think "I don't get it. 5mm if relatively inexpensive abrasive for $300".
There was a difference in surface finish between the cream and the king 8k. (1 micron stone vs. 3 or so). Necessary? No.
We didn't do duration tests or anything back then, we just sharpened the same plane several times and couldn't spot or feel anything between the shapton 16k, cream or 30k.
