Azabiki
Hank Knight
I'm in the market for an Azabiki. Can any of you Japanese tool guys recommend a good one?
Azabiki
Hank Knight
machine made from hida
David Weaver
Hida has a $33 machine made azebiki (fukagawa brand) that I've used on and off for years and it's been more accurate against a guide than any western saw I've used.
depth of cut without removing lateral material is limited to somewhere around the tooth depth, but for dadoes and such, it's no problem to cut half depth and then remove the waste side and the finish the cut.
Since there are so few teeth in the cut, I'm sure mine has dulled a little bit but the small number of teeth in the cut at any give time makes it so that it still saws well and quickly.
Re: machine made from hida
Hank Knight
Thanks, David. I've seen the Hida saw, but had no information about it. Your post helps.
Re: Azabiki
Wiley Horne
Hi Hank,
Try to match the saw to the scale of work. The saw you want for sawing, say, shop-made veneer or other thin stuff, is different than what you would use to saw a Drawer opening out of a 4/4 front rail.
To illustrate, I have two azebikis:
(1). 90mm/ 0.018 thickness/ rip=12ppi
(2) 75mm/ 0.013 thickness/ rip=14ppi.
Now, the 75mm saw has an entirely different feel than the 90mm, due to the 50% difference in plate thickness, and the finer toothing. Azebikis look alike, but they’re very different.
Am sorry I can’t make a specific recommendation, but did want you to have a way to think about what you’re looking for.
Wiley
Re: machine made from hida *LINK*
I recall purchasing that azebiki from Hida a few years ago. About a year ago I purchased another in Australia from JapanTools, a Hishika Azebiki. They look and feel the same to me.
You may recall I used it recently for stopped sliding dovetails ...
https://www.japanesetools.com.au/collections/saws/products/hishika-azebiki-sliding-dovetail-saw-90mm
Re: Azabiki
Hank Knight
Thanks, Wiley. That would never have occurred to me. I'll look for specs on the available saws. I probably want the larger one.
Re: Thanks for the link, Derek!
