More on this edge buffing thing...
David Weaver
(These pictures can be zoomed in very close)
..other stuff is getting in the way of making the last door on the cabinet, so I've only cut 12 mortises on cabinet doors (about 1 1/4" deep, 2" wide each - cherry).
Instead of choosing a good chisel, I chose one of my softer chisels and rounded the very tip of the chisel over on the buffer. The bevel on this chisel is otherwise probably about 25 degrees. (this is one of the wood handled buck brothers chisels - they are softer than most vintage chisels - this is a newer chisel, not an old one - BB's older chisels are on the soft side, too).
https://i.imgur.com/nCkJukL.jpg
It's not terribly sharp, but it's not damaged and can still be pushed through cherry end grain (this isn't after a refresh on the buffer, either, it's after 3 mortises). As part of the mortising, it probably saw the buffing wheel for about 5 seconds each time - 4 or 5 different times, something like once every 2-3 mortises. You can't see extreme particulars with the pictures, but what you can see is a lack of damage on a chisel that otherwise has a hard time avoiding damage, and without making the chisel resistive in the cut.
https://i.imgur.com/Bbv2bSc.jpg
(it could be fully resharpened easily, as the buffer hasn't removed much metal at the tip, only rounded the very tip over a little bit and only on the bevel side).
I also started to mortise a plane body a couple of days ago (this also prevents finishing the fourth door :| and getting the cabinet wrapped up), and used a sorby chisel. These are the newer sorby chisels - their edge holding is on par with low priced hardware store foreign chisels. I have no idea why they're so soft.
But in 10 minutes of mortising, it hit the buffer twice - once at the start, and once when my shoulder was getting tired. The mallet used is a 28 ounce verawood mallet, so it's not getting polite treatment.
https://i.imgur.com/XBOVBGE.jpg
It's not a fresh edge, so it doesn't look like one, but you can still pare with it. I sat these chisels aside when I bought them because I like the proportions (actually, I got several handle styles, too, finding sets on sale and eventually sold all but the cheapest version) and figured if I just got fed up with them, I'll reharden them.
total sharpening time for these is less than 30 seconds should they need more than the buffer. It would be weeks of regular use before I'd regrind.
https://i.imgur.com/5QzPd9f.jpg
And a fourth chisel that I forgot to picture in use is a harbor freight chisel on the right (these are long chisels, kind of light weight - they were about $8 for 6 or something of the sort, and are on the soft side. They have had a much uglier set of chisels than this for years now - these are long gone, but are a copy of some continental european type). I've used the chisel pictured to trim all of the tenon shoulders to the mark and pare all of the miters. Not exactly demanding use, but paring the shoulders is easier with this chisel than it has been with other normal setup chisels of mine because the grind is at about 20 degrees and just the very tip is rounded over. No strange failures.
I've always liked playing with various different types of chisels, but at this point am considering that it may be time to sell most of them (the point of the HF set was never for woodworking, either, it was to have a set of chisels that can be used for stuff like bathroom renovation where grout and adhesive mixed together just destroy a chisel - the one in the picture was spared).
The crux of all of this? There's less cut resistance from any of these chisels than there is from a "good" chisel set up at 30 degrees.
Re: More on this edge buffing thing...
Winston
This is really interesting stuff. A couple of questions: Does the buffer create a burr on the back of the blade, and if so, do you just buff the back as well? Also, do you think that a charged strop can provide similar results?
I've done similar...
John in NM
With smoothing plane blades. Great technique for really awful to plan wood, like bookmatched curly mesquite. I would hollow grind any flaws out and go right to a hard felt wheel on a hand crank buffer, charged with some grey stick polish for stainless steel. Works well, and is super fast. Just not as sexy as whatever flavor of stone one prefers.
I don't recall there being much burr, but I would also turn the blade over and remove whatever there was with a pass on the back parallel to the cutting edge.
Burr
David Weaver
I polish only the bevel side with any briskness. I do run the back of the chisel on the corner of the buff (which probably couldn't buff a thousandth off of something in 5 hour) briefly, but I can't feel any pronounced burr unless one is left from a prior step (in that case, it's better if not too much is left over as this doesn't remove enough metal to get rid of the burr just polishing on the bevel side).
I'm sure some approximate duplication from a strop could be created, but it's easier for the buff to be practically uncontaminated (meaning that if it has contaminants, I don't notice them either because they're thrown out, or because the buff isn't hard enough to back them in a way that they'll scratch a blade).
I have used loaded strops for various things over the years and am sure they could do this, but with more effort from the user - and the need to keep them clean and uncontaminated.
When you run into something...
David Weaver
and it works really well, you always expect (At least when I find something) that if you post about it, it's been done before.
I figure i'm not the first or the thousandth person to realize that it's not necessary to blunt the entire edge or put a precise guide-created facet.
