more on the door aesthetic...
David Weaver
i think it will be fine.
These doors are just loose. Door 1 on the right, learned a few things with it (remember, not a furniture maker) and door 2 on the left will require less finishing.
The top rail on the right side door....I dropped, and spoiled the miter fit and will remake once I'm done with the other doors if steaming that bead doesn't bring it back to something acceptable.
https://i.imgur.com/gKZeHmd.jpg
Changing brakes and rotors on a car, building a bunch of junk for a garden and fixing some other things has slowed time to make these. Once I have the panel and the rails ready to build, door two took about two hours. I don't know if an hour is possible profiling, grooving, mortising and fitting, but I aim to find out by door #4!!
This is the princely plane that does the grooving (a plane that I actually made for grooving drawer sides for the kitchen - it cuts off center on 3/4ths stock, but that turns out to be just what I need here to push the panel to the front of the rail a little bit and prevent a bead from having a tall flat side down to the door panel):
https://i.imgur.com/PNFuqeZ.jpg
https://i.imgur.com/cBPvrT0.jpg
Re: more on the door aesthetic...
nice looking door
Your shop looks like work goes on there. It will never make the cover of Fine Woodworking.
Ridin' the curl...
Jim Matthews
Noodle arms after catching something big enough to peel like dat.
Righteous
Re: Ridin' the curl...
David Weaver
You'd be pleasantly surprised by how easily one of these wooden skate planes cuts a groove. They're probably half the work of something with a metal skate.
Re: nice looking door
David Weaver
When I started making videos, I got some snide comments about needing to make the shop look more like a set, getting a camera person and doing some editing.
The decision to not baby things or clean all the time is what draws me into the shop.
It's satisfying, innit?
Jim Matthews
When a substantial strip just peels off, that's the best.
I'm wrestling with dado planes at the moment.
Half eject a continuous shaving, almost without effort.
The others jam in two passes.
I suspect the secret is in the lateral skew angle and mouth clearance.
Yours looks like Mario Lemieux skating through a crowded crease.
Re: It's satisfying, innit?
David Weaver
Yes on the older dado planes - they were made for a while by american makers as standards went into the toilet, so some can take a fair bit of experimenting to find the choke point. They're like a moving fillister plane that clogs - you can see everything right in front of you when you look at them, but it can be difficult to figure out exactly where the clog is starting and why. The good ones feed everything, against the grain or with it, grain running out, and the bad ones, nothing but good downgrain wood. I suspect good feed and not feed is a matter of a couple of degrees of angle somewhere or a tiny fraction of an inch (supposing everything is set up well and the iron and nicker aren't fighting to do the same thing at the edges of the cut).
Some of the later american dado planes that I've gotten have the front and back skate out of alignment a strong 32nd of an inch, but good in the sense that there's not much guilt of you hack one of them up into a plywood size. True everything up, make it all narrower, and grooving plywood is suddenly a lot quieter and without so much jigging.
